omnipower coilovers on kyb gr-2 shocks?
omnipower sleeves? the only coil sleeves i'd suggest are the ground controls. if you plan on dumping your car, i dont suggest kyb. if u go past 1.5 inches the warranty is voided. i have the gc/illuminas set up and it's stiff but smooth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90hbvtec »</TD></TR><TR><TD CLASS="quote">omni coilovers on stock shocks on my teg db8 rides very well for daily driving..not bumpy all..omni are awsome!!!!!</TD></TR></TABLE>
LOL. If the omni shocks have problems what makes you think stock or KYB GR2 will hold it.
Weak shocks like those will blow in no time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Another_EK_Hatch »</TD></TR><TR><TD CLASS="quote">omnipower sleeves? the only coil sleeves i'd suggest are the ground controls. if you plan on dumping your car, i dont suggest kyb. if u go past 1.5 inches the warranty is voided. i have the gc/illuminas set up and it's stiff but smooth</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">2. Exclusions from Warranty Coverage. The warranty does not apply outside of the United States and Canada or to any units which (1) have been improperly installed or installed on vehicles for which they were not designed, (2) have been modified, altered or subjected to misuse, negligence or accident on the vehicle on which installed, (3) are operated commercially, off-the-highway or for racing or (4) installed on excessively lowered vehicles. </TD></TR></TABLE>
They might even void the warranty on a 1" drop
tru tru my boy tells me agx are good, but i also see alot of people on here have koni's so wich should i get for my car? cuz im a noobie at this stuff...shocks or struts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer »</TD></TR><TR><TD CLASS="quote">You car has shocks, and I would koni's over all others if you plan on doing any track events or auto-x, if your just looking for a better street shock, agx's will fit the bill fine.</TD></TR></TABLE>
perfectly said
perfectly said
How much are you lowering it? If it's like 1.5-2.5 inches, you'd be fine with KYB AGX, if you want a little better, get Tokico Illuminas. Unless you really want to go all out and cough up the dough for Koni Yellows. The KYB AGX is cheapest out the 3, it shouldn't give you any problem unless you were really dumped maybe.
SickEj
Mar 4, 2003 01:13 PM
