ecu codes for 89 accord lxi
Old Aug 16, 2005 | 05:34 PM
thapimpfromchi's Avatar
Default ecu codes for 89 accord lxi
hey, does anyone know all the codes for an 89 accord lxi. we've counted, the light flashes 14 times. can anyone tell me what that means?
Old Aug 16, 2005 | 05:39 PM
fw190bvi's Avatar
Default Re: ecu codes for 89 accord lxi (thapimpfromchi)
89 is OBD0 isnt it?.......i have no idea
Old Aug 17, 2005 | 06:09 AM
deserthonda's Avatar
code 14 is an issue with idle control system....... lok around the EACV valve loose connection or valve itself could be bad..... i would clear the code and run engine again see if code comes back on
Old Aug 17, 2005 | 09:26 PM
sauceja's Avatar
I agree with deserthonda. To clear code pull the no. 11 under hood fuse in case you don't have the diagram that says ECU fuse. It is the EACV. I unplugged mine to find a problem on a 89 accord and got this code from our dealer book.
Ryan Haines
Dec 2, 2018 03:39 AM
Merlin13
Oct 29, 2018 05:01 PM
tknep
Nov 2, 2016 05:00 AM
Atomic646
Dec 16, 2012 08:05 PM
