****F/S B18B shortblock (semi built)****
From: South LA...107th and fig to be exact...for the foo
so cal only........please......
b18b block (legit)
GSR crank and rods
ARP rod bolts
New Honda main bearings
New Honda rod bearings
82mm Wiseco forged pistons (11.1 CR)
Total seal rings (XC's)
New oem oil pump
New oem water pump
includes oil pan, baffle, and p/up
all machining done by RS
This is a shortblock only, semi new...the bottem end has no more than 800 miles on it.....with my head and cams this motor made 235 on a dynapck dyno....dyno sheets available.....1100 dollars firm
Modified by myke at 5:33 PM 8/16/2005
b18b block (legit)
GSR crank and rods
ARP rod bolts
New oem oil pump
New oem water pump
