B18C ARP main studs, question for people that used them
Old Aug 16, 2005 | 04:06 PM
ninor's Avatar
Default B18C ARP main studs, question for people that used them
I am about to install a set, and wonder what tq value did other people use?
ARP info sheet is at 70, which seams kind of high for this...
Stock calls for 49 short and 56 long...
Anyway, help is appreciated.
Regards,
Nino
Old Aug 16, 2005 | 05:21 PM
unknown0001's Avatar
Default Re: B18C ARP main studs, question for people that used them (ninor)
Go with what ARP says since you do know...you are using their product and they would know the structural integrity of the studs and how much you can TQ them to.
Old Aug 16, 2005 | 09:34 PM
ninor's Avatar
Default Re: B18C ARP main studs, question for people that used them (Mr.RHTuner)
Well,
I went on one motor with their spec on Head Studs and it damaged the motor (shifted bores, and you can guess the rest). Snap On digital TQ, so I am confident tq was on the money.
This is my first time to use their main studs, therefore this question...
And I do agree, they do know structural integrity of their fasteners, but I am also sure that they do not know much about Honda blocks... It is true that each fastener requires certain pre-load to do it's thing, but there is always a bit of a range to play. While it is most certainly higher than stock, I would like to get on the lower end of given range...
Anyway, I know it is a long shot, but if anyone used these and would share their TQ numbers, I'd appreciate it...
Regards,
Nino
Old Oct 31, 2005 | 06:51 PM
Anti-Drama Queens's Avatar
bumping old question cause id like to know
Old Oct 31, 2005 | 07:06 PM
DEMNTD1's Avatar
Default Re: (mr_ducksauce)
I know ARP recommends that you align hone the block after insatlling the ARP main studs for the main caps.
nels00n
Aug 9, 2018 06:09 PM
pv2dickman
Apr 30, 2006 07:32 AM
SOHCD16y8
Mar 5, 2005 03:42 PM
s2kkid
Dec 12, 2004 05:42 PM
SCsol
Mar 23, 2002 06:39 PM
