What type of A/C bracket is my Sol supposed to have?
Old Aug 16, 2005 | 03:26 PM
Falqon's Avatar
Default What type of A/C bracket is my Sol supposed to have?
My 94 VTEC's previous owner deleted the air conditioning, I'd like it back. I cannot use a Sanden TRS090 or TRF090 because the holes do not line up on my P30 a/c bracket. Did the previous owner somehow switch out my a/c bracket or is P30 possiblely stock? If so, what compressor fits the P30? And what other engines came with P30 bracket stock so I can buy from a bigger used car base.
I searched, and have found so much conflicting information it's not funny.
Old Aug 16, 2005 | 05:17 PM
Falqon's Avatar
Default Re: What type of A/C bracket is my Sol supposed to have? (Falqon)
only bump I'll do, if it dies I guess oh well. Would really appreciate some knowledge though.
Old Aug 16, 2005 | 05:24 PM
Lord Helmet's Avatar
if it's indeed a del sol VTEC the bracket should be this Part # 38930-P54-000.
Or you can use this Part # 38930-P7J-000 from a CR-V which cost only half the price.
Old Aug 16, 2005 | 05:31 PM
Falqon's Avatar
Default Re: What type of A/C bracket is my Sol supposed to have? (Lord Helmet)
So what you're saying is the guy before me swapped brackets with a buddy who needed the a/c? That's entirely possible.
What about my P30 power steering? Will I have to change that back too if I get one of these p54 things?
Old Aug 16, 2005 | 05:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon &raquo;</TD></TR><TR><TD CLASS="quote">So what you're saying is the guy before me swapped brackets with a buddy who needed the a/c? That's entirely possible.
If it's not original I'm betting someone did swapped on the bracket.
What about my P30 power steering? Will I have to change that back too if I get one of these p54 things?</TD></TR></TABLE>
the power steering is exactly like the 5th gen civics aka EG/EJ and it won't be in the way. keep the stock power steering, just make sure the a/c bracket says P54 on it and you'll be fine.
Old Aug 16, 2005 | 05:40 PM
Falqon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">
Then what do P30 brackets come in originally?
Old Aug 16, 2005 | 05:42 PM
Then what do P30 brackets come in originally?</TD></TR></TABLE>
probably the del sol S model or Si model.
Old Aug 16, 2005 | 08:43 PM
Falqon's Avatar
I wasn't under the impression that brackets for DOHC would fit SOHC models,
Old Aug 17, 2005 | 04:39 AM
dwnthehatch's Avatar
Or you can use this Part # 38930-P7J-000 from a CR-V which cost only half the price. </TD></TR></TABLE>
The P7J bracket does not fit if you have power steering. Get the P54.
Old Aug 17, 2005 | 04:51 AM
CRXified's Avatar
when i got my JDM b16 swap my AC bracket has p30 stamped on it and had the AC compressor bolted to it still..
Old Aug 17, 2005 | 09:07 AM
Falqon's Avatar
Default Re: What type of A/C bracket is my Sol supposed to have? (CRXified)
I called the honda dealership, apparently 96-97 VTEC's are supposed to have p30's. Really wierd that they changed to a different compressor mid chassis design for no apparent reason.
Mentat Ghola
Feb 24, 2009 01:47 PM
honda305
Jan 1, 2009 03:55 PM
IMPATIENT
Mar 22, 2006 06:46 AM
civic_speed99
Mar 18, 2005 11:43 AM
jdhybrid
Nov 9, 2004 02:29 PM
