Vtec rocker arm question.
Old Aug 16, 2005 | 12:40 PM
matix's Avatar
Default Vtec rocker arm question.
Ok I bought some rockers for my h22. They were already machined for my crower valvetrain. I brought everything to my local machine shop and had it all assembled. I got it back and realized the secondary rockers dont have that little pin that sticks out the side. The primary and secondary rocker arms had it on my other rocker arms. I was wondering if this would affect anything. I am able to move both the primary and vtec lobe up while the secondary stays down, its able to seperate from the other two bc that pin seems to be machined off.
Old Aug 16, 2005 | 12:41 PM
matix's Avatar
Default Re: Vtec rocker arm question. (matix)
Just incase im not talking about the pistons in the rocker arms. Im talking about that little pin thing that sticks out the side and makes it so you cant sepertae them from the vtec rocker.
Old Aug 16, 2005 | 05:40 PM
matix's Avatar
Anyone?
Old Aug 17, 2005 | 01:58 AM
ekek888's Avatar
on the b16, im only assuming its the same, the pin are inside and pushed out to lock the rockers to the hi cam lobe during vtec, if it was grinded down, your engine will be on lo cam profile even if the pin is pushed out. [doesnt lock anything bec its shortened.]
i strongly suggest to have it checked by a qualified mechanic.
Old Aug 17, 2005 | 12:33 PM
matix's Avatar
Default Re: Vtec rocker arm question. (ekek888)
Im not talking about the actuall dowel things inside. Im talking about the thing that sticks out the side of the rocker arms to somewhat keep them together.
lude98SH
31
Dec 15, 2006 06:16 PM
SPOOLINmatt
May 22, 2005 08:28 PM
Nic
Oct 14, 2004 02:31 PM
Cashflo
Sep 18, 2003 09:29 AM
Threshld1
Jul 13, 2002 10:35 PM
