Toda B's with .015 thous off the head, and 2 layer head gasket?
Old Feb 22, 2002 | 07:58 PM
TypeR0149's Avatar
Default Toda B's with .015 thous off the head, and 2 layer?
well like it or not this will be my setup, I wonder if I will be slapping some pistons.
any input or anyone running something like this? how far can I advance the cams?
the clearance issue is beggining to worry me, and no I am not gonna drop in new pistons to get compression, I dont care that much
Old Feb 22, 2002 | 08:00 PM
MackSpeed-616's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (Vegeta)
so why dont you clay check if you are worried??
Old Feb 22, 2002 | 08:01 PM
TypeR0149's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (TurboR616)
cause I want compression, im not really worried just currious to see if i will ***** up my motor
Old Feb 23, 2002 | 08:13 AM
TypeR0149's Avatar
hmm well if I have clearance issue's i'm sending the bill to the Type R forum
Old Feb 23, 2002 | 08:20 AM
Digital-R's Avatar
No sweat...I have a 1 layer gasket, with ..020 off the head with B's. Also on Wednesday I am putting in Roller waves.
Old Feb 23, 2002 | 08:21 AM
Mr. Softee's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (Digital-R)
i have 26 off my head with jun3s and b16 pistons and im fine. in case you care heh.
Old Feb 23, 2002 | 09:49 AM
Liquidx02's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (94goldjungsr)
You will be fine. But you should clay the motor. Toda Bs arent just going to be a drop in mod. Your going to have to tune them with gears. Your not going to have any idea what your clearance is going to be with the head being milled. Last thing you want to do is slap the valve with a piston. It will be time for a new engine if that happens. Im running JUN IIIs with CTR pistons. I have very little room to play with
Old Feb 23, 2002 | 04:03 PM
JDM_DOHC_SiR's Avatar
New User
You'll be fine... I have .040 off my head and I and standard head gasket no problems with the B's
Old Feb 23, 2002 | 05:02 PM
ImportReview
Guest
Posts: n/a
Default Re: Toda B's with .015 thous off the head, and 2 layer? (JDM_DOHC_SiR)
Well, if you use JE pistons, they have 40 thousands more clearance than rollerwaves...
so your way safer.
Jeff
Old Feb 23, 2002 | 05:07 PM
TypeR0149's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (ImportReview)
so your way safer.
Jeff
I am running stock b18c5
15 thous off the head, and a 2 layer so it is like .027 thous off the head, what can I do with my cam gears, i mean how advanced and retarded can I go
Old Feb 23, 2002 | 05:25 PM
gsr98vtec's Avatar
dont go to far on the advance, some people knock that up to like +7, i would be weary of that, and mike you should clay it to be sure anyway, talk to sgT isnt he doing your tuning, he will tell you for sure
[Modified by gsr98vtec, 9:26 PM 2/23/2002]
Old Feb 23, 2002 | 07:43 PM
SuperTwinz's Avatar
question: why dont people just get hi comp pistons instead of millng their heads?
Old Feb 23, 2002 | 08:37 PM
TypeR0149's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (SuperTwinz)
Awnser: its alot less money, and more reliable as long as you dont go to extreme
Old Feb 23, 2002 | 08:50 PM
nfn15037's Avatar
How is it more reliable? A forged piston is much better than a stock cast piston in terms of detonation resistance.
Old Feb 23, 2002 | 09:07 PM
TypeR0149's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (nfn15037)
its more reliable in the fact I am not touching my bottem end, every bottem end I have seen been takin apart has had some problem, not big, but I like my car to have stock reliability, plus I just swap a stock Type R head back on there take off my bolt-ons, for warrenty work, if I have RW pistons, i would have a hard time having acura warrenty any engine work
Old Feb 23, 2002 | 09:54 PM
nfn15037's Avatar
Thats kindof the price you pay for modding your motor man. Not to be a dick or anything, but thats fucked up if you mess your motor up, take all the mods off, and take it in for warranty
Old Feb 23, 2002 | 10:00 PM
TypeR0149's Avatar
well I did pay for a warrenty when I bought the car, so I think I am entitled to use it,all new cars have fixed into there price the estimated cost of the warrenty repairs for that model of car. or its history of repair. when I bought my Type R, If i could of gotten back $800-1200 for the warreny I would of. however as a consumer moddifying my car and then taking my car into to warrenty work, I hurt no one, the only person that I am hurting by not taking it in is myself because I did not get full value for my car. everything comes down to economics. I will take my car for warrenty work if it comes to it.HOWEVER if I bend a valve MY faualt i replace the valce, I spin a bearing Honda's fault they fix my short block. because I didnt touch it. I am not scamming only asking for my fair share
Old Feb 23, 2002 | 10:06 PM
nfn15037's Avatar
Thats cool man, i thought you wer planning for when you bent a valve or some crap like that. Good luck with the projest man!
[Modified by nfn15037, 11:06 PM 2/23/2002]
Old Feb 23, 2002 | 10:09 PM
TypeR0149's Avatar
well see Its kinda a love/hate thing now. like I want the spec B's for everything the have to offer.
but I dont want the spec B's for everthing they have to offer.
thats sounds retarded but I think most understand where I am comming from, once I fly a tunner down everything will be OK
Old Feb 23, 2002 | 10:22 PM
ImportReview
Guest
Posts: n/a
Fly me there man!
haha. Give me Hondata and a wideband and youll have the science of perfection.
Jeff
Old Feb 23, 2002 | 10:23 PM
TypeR0149's Avatar
Fly me there man!
Jeff
flights are expensive from Cali...but not from virginia
Old Feb 24, 2002 | 01:31 AM
gsr98vtec's Avatar
somebodies dialin up sgT. Mike its called priceline. 148 to san diego next week for a long needed vacation. saved 600+ on the flight
Old Feb 24, 2002 | 07:12 AM
TypeR0149's Avatar
Default Re: Toda B's with .015 thous off the head, and 2 layer? (gsr98vtec)
yea I have got some quotes from there
nfg177
May 31, 2008 06:05 AM
Leventis
Apr 20, 2005 10:19 PM
jansenrw
Apr 9, 2003 05:13 AM
Mad Cow Disease
Nov 12, 2002 12:41 PM
WayneGro
Nov 30, 2001 06:31 PM
