Pesky fuel leak
Old Aug 16, 2005 | 08:50 AM
whiteturbohatch's Avatar
Default Pesky fuel leak
The Car: 1990 Civic hatchback.
The problem: Ok, i replaced my fuel pump with a 255LPH and changed the gas tank. I live in the north east so there sia bit of rust, but not a ton. The return line keeps leaking at the rubber hose, on the tank side...i've replaced the hose 2 times and its still leaks there. i even slid the hose on a few inches furhter (and a second clamp) thinking there was a leak on the steel line, it still leaks. Anyone have any ideas? I was thinking steel braided, but cant find any adaptors from 8mm steel line to an -AN fitting.
Thanks,
Travis
Old Aug 16, 2005 | 01:01 PM
JimBlake's Avatar
Default Re: Pesky fuel leak (whiteturbohatch)
First make sure it isn't the steel tube leaking. That happened to me, the tube itself gets tiny perforations from the rust.
tolowhb
16
Jul 24, 2020 07:37 AM
Sorcerer
Jan 21, 2017 11:13 AM
vulch
May 8, 2015 08:09 AM
vtrp2008
Sep 4, 2014 08:55 AM
s13_240sx_92
Dec 6, 2006 08:44 AM
