ENDYN girdle on ls, what is needed from GSR??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">you will also need the gsr oil pan and have it align honed</TD></TR></TABLE>
wha?
wha?
yeah def need an align bore. When i installed my girdle and torqued everything down the crank was practically seized. Went and got a line bore and then it was smooth as silk.
Also, u dont really need a gsr oil pan, u just need a hammer and u can pound out a spot in the pan to clear the pickup and stuff. The key thing here is after you bang out a dent for the extra clearance, make sure u turn the pan upside down flatten out the area where the gasket goes in order 2 get a good seal.
It all depends how much u can find a gsr pan 4 but i know that u can do this method and it will work just fine.
