403whp / 280 Torque @ 20 psi Stock Block (No Sleeves) GSR
Old Aug 16, 2005 | 08:02 AM
CharlieGSR's Avatar
New User
Default 403whp / 280 Torque @ 20 psi Stock Block (No Sleeves) GSR
These are the Dyno Numbers of my Turbo GSR without sleeves.
Old Aug 16, 2005 | 08:07 AM
11psiTurboSI's Avatar
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (No Sleeves) GSR (CharlieGSR)
All I see is a X
Old Aug 16, 2005 | 08:08 AM
delslo93's Avatar
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">All I see is a X</TD></TR></TABLE>
diddo
Old Aug 16, 2005 | 08:11 AM
CharlieGSR's Avatar
New User
Sorry You Should be able to see it now!!!
http://www.lafiebrepr.com/imag...r.jpg
Old Aug 16, 2005 | 08:13 AM
RobbieG35's Avatar
12 Years Strong
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (CharlieGSR)
Nice, whats the set-up?
Old Aug 16, 2005 | 08:22 AM
Blackack26's Avatar
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (HybridHatch88)
Stock block as in stock internals? or just stock sleeves with forged stuff?
Nice numbers, whats the setup?
Nice #'s
Old Aug 16, 2005 | 08:25 AM
D-tuned's Avatar
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (Blackack26)
nice #'s how about some info about the turbo set-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">Stock block as in stock internals? or just stock sleeves with forged stuff?
Nice numbers, whats the setup? </TD></TR></TABLE>
Old Aug 16, 2005 | 08:32 AM
CharlieGSR's Avatar
New User
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (D-tuned)
Stock Sleeves with Forged Pistons and Rods
This is the setup
10.1 Forged Pistons
Peak Performance Forged Rods
T3/T4 .63/.70
3 Inch Exhaust
Microtech Fuel Management
stock cams
stock intake manifold
stock throttle body
Old Aug 16, 2005 | 08:38 AM
tuoniz's Avatar
Nice #'$
Old Aug 16, 2005 | 08:42 AM
Jared's Avatar
sweet powerband
Old Aug 16, 2005 | 08:43 AM
Chunty Butt Kevin's Avatar
nice
Old Aug 16, 2005 | 08:44 AM
CharlieGSR's Avatar
New User
Thanks!!! The Blue Line was at Low Boost 12 psi
Old Aug 16, 2005 | 08:46 AM
G
sh!t happens.
Nice power band.. what manifold are you running?
Old Aug 16, 2005 | 08:48 AM
CharlieGSR's Avatar
New User
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (G"UNIT)
Tha Manifold was custom build locally. It's basically a log type Manifold.
Old Aug 16, 2005 | 08:50 AM
Was 403whp/280tq done on pump gas?
Old Aug 16, 2005 | 08:53 AM
CharlieGSR's Avatar
New User
The Blue Line Which is at Low Boost was on Pump Gas 93 Octane. The Red Line Was at High Boost and I just added 3 Gallons of 116 Octane Racing Gasoline.
Here's a pic of the Engine
Old Aug 16, 2005 | 08:56 AM
tunedbylorange.com's Avatar
good #'s with the log
Old Aug 16, 2005 | 09:51 AM
Finland's Avatar
Wow, lots of people lately making big power on stock sleeves, I'm curious as to how long they hold the power. Nice numbers.
Old Aug 16, 2005 | 09:56 AM
B18 CYA's Avatar
what was your timing at? im hittin up the dyno tomorrow and hope to make 400 at 25-26 psi with a smaller turbo on stock sleeves. Thanks
Old Aug 16, 2005 | 09:59 AM
rocket256's Avatar
Default Re: (Boondock Saint)
Now all you have to do is take it to the track to see what she'll run!
Old Aug 16, 2005 | 10:34 AM
uptownrickyv's Avatar
Nice numbers
Old Aug 16, 2005 | 10:45 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: 403whp / 280 Torque @ 20 psi Stock Block (uptownrickyv)
nice, how many lbs was your high boost set at??? i would bet that you could make 400 on 93 octane......
Old Aug 16, 2005 | 12:49 PM
spoolin-ls's Avatar
nice numbers! hope those sleeves don't crack...
Old Aug 16, 2005 | 01:29 PM
cuin9sec
Guest
Posts: n/a
Default Re: (spoolin-ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin-ls &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers! hope those sleeves don't crack...
they wont as long as its tuned right...
