check engine light after hi flow cat?
recently installed header and hi flow cat to 2000 d16y8. after a day or so i was getting on her a little bit and the check engine light popped up. i asked some friends at the local shop if this was because of new install, and they said it was. anyone ever hear of this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Assuming you checked the code, and it turned up as 2ndary o2 sensor or cat inefficiency = Yes - what brand is it?
Did you plug youre o2 sensor back in?</TD></TR></TABLE>
That's what it sounds like to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">That's what it sounds like to me.</TD></TR></TABLE>
Same.. First thing I thought of was O2 sensor. Do you even have one now?
Probably didn't install your 02 sensor right or the computer's not recognizing it. Try pulling your negative terminal, put it back on and let the car idle for about 5 mins.
hndacord02
Jan 18, 2006 12:02 PM
Vt3cTun3r
Apr 29, 2004 03:01 AM
tegrunner
Sep 11, 2003 07:54 PM
