94 Accord stalls when A/C on and not driving
Old Aug 16, 2005 | 05:54 AM
gregc's Avatar
Default 94 Accord stalls when A/C on and not driving
My a/c works well when the car is moving. When stopped, the air gradually warms up and then the engine stalls. At first, the idle would just drop but the problem has progressed to where the engine stalls every time. If I turn off the air when stopped, engine runs normal. I verified the fan is turning. Thanks for any advice.
Old Aug 16, 2005 | 10:11 AM
Chiovnidca's Avatar
Default Re: 94 Accord stalls when A/C on and not driving (gregc)
Do both the cooling fans run with the ac on?
Old Aug 16, 2005 | 12:10 PM
BoostedH23Accord's Avatar
Default Re: 94 Accord stalls when A/C on and not driving (Chiovnidca)
Have you tried turning the engine idle up to see if that corrects the problem?
Old Aug 17, 2005 | 10:46 AM
gregc's Avatar
The radiator fan is not spinning. Is it supposed to spin all the time or is it controlled by water temp?
Old Aug 17, 2005 | 10:48 AM
gregc's Avatar
Default Re: 94 Accord stalls when A/C on and not driving (BoostedH23Accord)
No I haven't tried adjusting the idle RPM. When the problem occurs the engine RPM becomes erratic and usually stalls. I put it in neutral once and rev'd RPM up while problem was occurring and RPM was still very erratic. I could hear a relay clicking on and off with a corresponding change in RPM. Thanks.
Old Aug 17, 2005 | 11:06 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gregc &raquo;</TD></TR><TR><TD CLASS="quote">The radiator fan is not spinning. Is it supposed to spin all the time or is it controlled by water temp?</TD></TR></TABLE>
That's probably the problem, both fans should run with the ac on.
Old Aug 17, 2005 | 12:33 PM
gregc's Avatar
I checked the fan and it's electrically open. I'm gonna go get a new one. Thanks man.
Old Aug 18, 2005 | 10:54 AM
scottc011's Avatar
I had a similiar problem with my 03 Accord. The fuse was blown for the radiator fan and I replaced it. It blew right away. I unplugged the power from the fan and put in a new fuse. Plugged the power back into the fan and both fans started to work. I noticed if the fuse to the radiator fan is blown the condensor fan won't work either.. yet it has its own fuse. The condensor starts up for the AC and goes right off when the condensor fan won't start up. Check the fuses!
Old Aug 26, 2005 | 02:12 PM
gregc's Avatar
I replaced the radiator fan and now the problem is solved. Thanks for the help guys.
bno89
Oct 27, 2014 05:20 PM
sorce_money
Dec 19, 2004 10:32 AM
SirRevvs
Dec 3, 2004 11:30 AM
schtozo
Mar 26, 2003 06:53 PM
