NEED GUIDENCE ON CAMS
Old Aug 15, 2005 | 09:51 PM
typeReg's Avatar
Default NEED GUIDENCE ON CAMS
I got a 97 jdm ITR, its' virtually stock with bolt on's. I wanna get some good cams but I dont want to sacrifice reliability. What cam's would you guys suggest?
Old Aug 15, 2005 | 10:05 PM
noboostedEGo's Avatar
Default Re: NEED GUIDENCE ON CAMS (typeReg)
Do you wanna stick with your stock compression, redline, valvetrain, etc.? What r ur plans?
Old Aug 15, 2005 | 10:11 PM
chinese acrobat's Avatar
Sell stocks get toda b spec
excellent for N/A
Old Aug 15, 2005 | 11:03 PM
mtber's Avatar
Default Re: (chinese acrobat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinese acrobat &raquo;</TD></TR><TR><TD CLASS="quote">Sell stocks get toda b spec
excellent for N/A</TD></TR></TABLE>
Toda b's require aftermarket valvesprings....
What I always recommend:
a. Figure out how fast you want to be. (13s etc)
b. Figure out how much power it will take to be that fast.
c. Figure out what is required to meet those goals.
Old Aug 16, 2005 | 07:34 AM
typeReg's Avatar
Default Re: (mtber)
Well at this time I dont want to change any internals besides the cams.
Right now the motor is in a EG with ac . I want just some more power. The car runs really strong with current bolt ons
intake
type r fuel rail, fuel pump
aem f.p.r
98 R header
2.5 pipping es tuning muffler
mugen ecu
msd ignition and external coil
Ive never tracked it but on the gtech it runs mid to high 13's
That being said what cams should I run without changing the valvetrain or springs?
O i plan to get some cam gears to
Old Aug 16, 2005 | 09:30 AM
92Jspec's Avatar
Default Re: (typeReg)
blox type a's
Old Aug 16, 2005 | 11:01 AM
Sahwn's Avatar
how much money r u willing to spend? As far as the type-r goes, I don't think JUST cams will give you much of a difference in power. You might just want to save up some more money and up grade the valve train and get the better cams to go with it. Of course, do some tunning when you get your new set up.....so more money there too.
Old Aug 16, 2005 | 01:43 PM
Jowee's Avatar
Default Re: (rsg74)
You should easily be in the high 13s with a stock JDM ITR engine in an EG with good driving. I would look at a better header first then possibly gettting a spare head built for some nice cams with a 2 layer HG and selling off that OEM ITR head.
If you want reliability, keep it the way it is and just do bolt ons. I've got 91k on my stock engine with nothing more than bolt ons and have 0 problems reving to 9k with 230 psi across all 4 cylinders.
hamizle
Oct 25, 2008 03:37 AM
.Mason
Apr 11, 2008 08:53 AM
RicTRD
Mar 16, 2005 01:43 PM
teethandnails
Oct 23, 2004 04:49 PM
itr_18
Nov 3, 2003 12:24 PM
