toda cams and boost????
Old Oct 23, 2008 | 09:13 PM
hamizle's Avatar
Default toda cams and boost????
im thinking of getting some toda cams and boosting my car, but not sure how its going to end up i dont want a broken shaft.. let me know what you guys think
Old Oct 23, 2008 | 09:33 PM
00-501itrspec's Avatar
Default Re: toda cams and boost???? (hamizle)
If you build a Proper Turbo setup , you wont have a need for some crazy Toda cams , Just use some GSR/ITR cams .
It all depends on your setup and what you want from it .
But your question is very vague , be more specific next time .
Old Oct 23, 2008 | 09:42 PM
tony413's Avatar
theres different toda cams. so asking "if i use toda cams and boost is that ok?" doesnt help be more specific
Old Oct 24, 2008 | 08:33 AM
TheShodan's Avatar
Moderator
Default Re: (tony413)
Even on 500whp power goals, Toda cams of any size other than Toda As are unncessary. STock GS-Rs and Type Rs do MORE than the job when it comes to boost.
Old Oct 24, 2008 | 08:49 AM
Schister66's Avatar
Man U FTW
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Even on 500whp power goals, Toda cams of any size other than Toda As are unncessary. STock GS-Rs and Type Rs do MORE than the job when it comes to boost.</TD></TR></TABLE>
I agree.
Us Honda guys are so lucky, but not many of us realize it. Stock Honda heads and cams flow very well. We can get away with running stock-port heads and OEM cams even for very high hp. There's really no need to upgrade to some wildly aggressive cam for your goals. That's not to say you wont see gains, but for the money you spend, it might not be worthwhile
Old Oct 24, 2008 | 08:56 AM
hamizle's Avatar
Default Re: (Schister66)
ya after looking into it i think am going to go with some itr's thanks for everyones help
Old Oct 24, 2008 | 02:42 PM
12sec14's Avatar
I actually have some Toda spec B cams just sitting around... Would there be too much duration for a Bone stock B16 Turbo?
I dont mean to be a noob but I am new to this boost game (been in it for 7 days now)!
My car made around 155ft/lb and 218bhp on a dyno dynamics RR @ around 0.4lb of boost.
I was interested to see what would happen at 9psi with the Toda's. (im too used to NASP)
Old Oct 24, 2008 | 05:08 PM
TheShodan's Avatar
Moderator
Default Re: (12sec14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12sec14 &raquo;</TD></TR><TR><TD CLASS="quote">I actually have some Toda spec B cams just sitting around... Would there be too much duration for a Bone stock B16 Turbo?
I was interested to see what would happen at 9psi with the Toda's. (im too used to NASP)</TD></TR></TABLE>
At those power levels, nothing would change very much. You need to understand that unlike the NA setups, you don't scavange for the air coming into the chamber, it is forced. Untill you're over 600whp, only then are cams necessary (and even then they are a different design) for top end power..
Old Oct 24, 2008 | 11:29 PM
megatoninduk's Avatar
Chiming in late as usual, but gsr/itr cams seem to be doing the trick on mild to even wild set-ups. My car is making 600whp on gsr cams, but I have herd really good things about the skunk 2 pro 1's or the blox cams that are essentially the same thing. Most of the guys I've seen with anything more aggressive than itr cams are making more power than me though... just my 2cents
Old Oct 25, 2008 | 03:37 AM
12sec14's Avatar
Nice one, thanks for the advice.
BlakeJ53
Oct 2, 2008 07:17 AM
Drew17th
Aug 28, 2007 12:51 PM
EGkid
Jan 4, 2005 07:04 PM
hqrcrx
Dec 10, 2004 06:48 PM
