Idle Air Control Valve...how do you take it off to clean it?
Old Aug 15, 2005 | 08:46 PM
SavEM1's Avatar
Default *deleated*
Modified by Hcivic02 at 6:02 AM 8/16/2005
Old Aug 15, 2005 | 09:10 PM
CrotchRocket's Avatar
Default Re: *deleated* (Hcivic02)
Use a 12m wrench and a set of pliers to remove the hose.
1. Turn engine off
2. Let Engine cool off
3. Disconnect electrical plug
4. Remove 2 bolts (12mm)
5. Disconnect hose using pliers (2)
6. Use carb cleaner spray to clean it out.
7. To reinstall, follow steps backwards.
You should also test to see if it is functional by jumping your ECU or using a voltmeter. This way, you should hear it click while the engine is in ON position. Please refer to the ECU thread for the proper ecu location to jump.
thunderboy
Sep 2, 2008 03:41 PM
JBirch_97Prelude
Aug 16, 2007 04:40 PM
sickassride
Jun 4, 2006 12:14 PM
Xtian8
Sep 12, 2004 12:37 PM
BackSideSA
Mar 2, 2003 01:55 PM
