3540 Prop Valve
Old Aug 15, 2005 | 06:58 PM
SAVIOVEGA's Avatar
Default 3540 Prop Valve
I have a 95 DX with stock front discs and rear discs from a 90 Integra. Currently I have the stock 3030 prop valve and 13/16 MC. I plan on changing to a 15/16 MC and was wondering if I needed the 4040 prop valve or if I could use a 3540 prop valve. How much of a difference would it make between 4040 and 3540 ? Would the weight of an H22 affect what prop valve to use ??? Just wondering.
Modified by SAVIOVEGA at 8:21 AM 8/16/2005
Old Aug 16, 2005 | 04:24 AM
SAVIOVEGA's Avatar
Default Re: 3540 Prop Valve (SAVIOVEGA)
Old Aug 16, 2005 | 04:08 PM
SAVIOVEGA's Avatar
Old Aug 16, 2005 | 04:28 PM
Tyson's Avatar
i dont think theres much of a difference between the 3540 and 4040 prop valves, as much as the difference of 3030.
but given the choice, i would use the 4040. heres why. the 3540 came stock on the 4dr civic EX with large front brakes and drums in the rear. the integra has large front brakes and calipers in the rear, and has a 4040. 3540 seems to give more front bias. seeing that you have calipers in the rear, but normal brakes up front, perhaps the 4040 would be more ideal to equalize the use of the rear caliper.
Old Aug 16, 2005 | 06:16 PM
Lord Helmet's Avatar
Default Re: 3540 Prop Valve (Tyson)
I'm using the 3040 PP from a 95 civic SI with a 15/16 MC on my EJ1 and it works wonderful. BTW Tyson is right the differences is minimal from the 3540 to 4040 PP valve. But the differences from 13/16 to 15/16 is a big differences. My EJ1 originally had a 7/8 MC but when I switched to the 15/16 it definitely brakes more smoother and more equally too.
Old Aug 16, 2005 | 07:57 PM
SAVIOVEGA's Avatar
Default Re: 3540 Prop Valve (Lord Helmet)
Thanks for the replies
crower
Nov 15, 2015 05:59 PM
SoCal EJ1
Suspension & Brakes
Oct 31, 2008 07:38 PM
EL Vap133
47
Dec 19, 2003 08:27 AM
chronic
Sep 24, 2002 07:58 AM
Giuseppe
Jan 6, 2002 12:08 AM
