Cant find How to Socket P28 for Hondata
I searched but I cant find how to socket the p28 ecu..It came with 2 what I think are resistors and the socket..Is there a diagram and are the resistors directional..sorry for the simple terms...
try http://www.pgmfi.org
it takes practice, trial and error to get use to soldering the chips in...but its not that bad..i would suggest if you have an extra ecu to practice on, do so..practice desoldering on it first and apply solder back in and take your time...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">I have seen many people destroy perfectly good ecus. </TD></TR></TABLE>
Yeah, but those people are usually monkeys with substandard IQs. Seriously, I tought myslef how to solder when I was 12, it's not hard by any standard.
Myself (and many others) like Keebler's write-up: http://home.mn.rr.com/keebler6....html
EDIT: Lol, okay, so maybe I'm the one with the substandard IQ since I just re-posted the Keebler65 link.
I work with solder and circuitry alot..im in the telephone installation business. All i need to know is where the items that come with the Hondata s200 go.I know where the 2 chips and socket go but there is a power connector and 2 small resistors.I need some kind of diagram or picture is all im looking for.
http://hondata.com/downloads.html ... there is the link right there .. they also have a ECU diagram .. make sure u go to tech .. then download the 27 pages of info u will need.. hope that helps out
Its ALL in the link i posted above!!!! in keeblers write up of using the USB nokia phone wire to datalog, he solders in three wires to port CN2. for hondata, u need to desolder that section of CN2 and solder in the white pin clip thingy
here: http://home.mn.rr.com/keebler6....html
A friend of mine had a p28 chipped differently than what Keebler says. The thing was chipped with only one of the capacitors and there was also something else different, but the thing worked with s200b.
edit: Just do what Hondata says to do for the s200, it will probably make your life much easier than if you tried to do Keebler's method.
http://hondata.com/downloads/s...l.doc
http://www.pgmfi.org/twiki/bin...pping
This is my favorite write-up...and I have the parts you need including the little white 4 pin header in a nifty little 'package' as well.
Chipping Kit
Chipping Kit
