Low on Oil? When to measure?
Old Feb 22, 2002 | 03:39 PM
onyx00's Avatar
Default Low on Oil? When to measure?
Alright, the car was run about 3-4 hours ago; engine is still warm, I went to look at my oil level and it was below the lower hole on the dipstick.
Does this mean I am really low? Because I would think the long the car sits the more oil would drain in to the oil pan and the higher the oil level would appear to be. Is this correct?
I am going to go add some Mobil One now but can someone let me know anyways. Thanks!
Old Feb 22, 2002 | 03:56 PM
Bbasso's Avatar
Default Re: Low on Oil? When to measure? (onyx00)
this is what i look for in checking the oil level,
1st the car must be level
2nd when i check the oil i let it sit over night in the garage, ice cold
3rd the first pull i just clean it off the second and third pull is to take the measurement
not too hard right? but i do this every other time i open the garage to take the beast out
hope i helped you...
Old Feb 22, 2002 | 05:10 PM
Chris's Avatar
Default Re: Low on Oil? When to measure? (Bbasso)
Just make sure its been sitting for 5 min to let the oil settle, and level.
Old Feb 22, 2002 | 07:14 PM
magic hat #9's Avatar
add oil, dude! you should take your measurement within 30min of stopping the motor.
Old Feb 22, 2002 | 07:18 PM
Eric R's Avatar
If that your case, you need to add about one quart of oil.
Anyway, doble check!
Old Feb 22, 2002 | 08:12 PM
Dirt's Avatar
Default Re: Low on Oil? When to measure? ('01ITR#950)
Checking the oil when the engine is warm is pointless.
Wait until all the oil has drained into the pan (3-4 hours after shutdown) or when the engine is cold.
[Modified by MmmVTEC, 9:13 PM 2/22/2002]
Old Feb 22, 2002 | 08:17 PM
Art Vandeleigh's Avatar
Default Re: Low on Oil? When to measure? (MmmVTEC)
Old Feb 22, 2002 | 08:30 PM
EG8R's Avatar
Default Re: Low on Oil? When to measure? (cali-r)
3-4 hours to let oil drain to the pan LOL Chit man just check it 5 mins after. Like it was said earlier.
Old Feb 22, 2002 | 08:53 PM
Chris's Avatar
Would you care to elaborate on that point?
Why would you need to wait more? Its not Heinze Ketchup...
Old Feb 22, 2002 | 11:54 PM
dustin's Avatar
Default Re: Low on Oil? When to measure? (Chris)
Umm, you are supposed to check the oil when the engine is warm. If you check it when the engine is cold it will read low... oil expands when it gets hot.
Dustin
ramboPandA
Oct 4, 2013 10:20 PM
highwhey
Nov 11, 2010 05:53 AM
iGGY366
Honda Civic (2001 - 2005)
Dec 6, 2007 02:17 AM
Exeed
Aug 24, 2006 12:37 PM
dose
Aug 8, 2002 09:20 AM
