Rough IDLE ITR cams in a B16...........
Old Aug 15, 2005 | 06:06 PM
ALLMOTOR00SI's Avatar
Default Rough IDLE ITR cams in a B16...........
i have a B16a2 with a skunk 2, manifold Itr header, itr cams, aem cam gears adjusted +2 intake and -2 exhaust. the idle on my car is a bit rough. and when i took off my piping to run straight header it sounds like it has some big cams in there. is this normal?? maybe cause the cams have been adjusted? just wanna know before i go run at the track.
Old Aug 15, 2005 | 06:49 PM
insomniac791's Avatar
Did you adjust your valves when you were
done?
Old Aug 15, 2005 | 07:32 PM
Default Re: (insomniac791)
yes i did a valve clearance adjustment to .008
Old Aug 15, 2005 | 07:35 PM
is it possible that since the cam gears are adjusted with ITR cams on stock valve train that the idle will change?
EK Dave
13
Jul 25, 2007 11:43 AM
gsrjohnny
Oct 6, 2006 03:46 PM
Capt. Jimbo McSubipants
26
Mar 17, 2005 06:53 PM
vti444
14
Feb 3, 2005 05:56 PM
PYITR821
Jan 21, 2003 04:52 AM
