NEED HELP ASAP!!! about bleeder screw??!
Old Aug 15, 2005 | 05:35 PM
RapeV-8's Avatar
Default NEED HELP ASAP!!! about bleeder screw??!
ok i have a 91 std civic hb and i was bleeding the rear drum brake today and i broke the bleeder screw?!!! ok now my question y isnt leaking?? my paking/braking is fine w/ NO LEAKS??!! should i fix this problem at all?
Old Aug 15, 2005 | 05:50 PM
civic_dork's Avatar
Default Re: NEED HELP ASAP!!! about bleeder screw??! (igotcrx)
Probably isn't leaking because you just happened to snap it off above the check ball/valve.
Should you fix it? Are you kidding.... you are kidding right? YES!!!
Old Aug 15, 2005 | 06:23 PM
RapeV-8's Avatar
how should i fix it?get a new brake cylinder?
H0nda_Crazy
Feb 8, 2015 05:28 PM
keith1993may
Apr 16, 2013 04:33 PM
bigluelok
Jul 25, 2009 11:22 AM
xwhitchx
Apr 22, 2009 05:07 PM
gilbert90605
Mar 9, 2009 06:28 PM
