Car not starting
Old Aug 15, 2005 | 05:14 PM
icer350's Avatar
Default Car not starting
Alright, I am having this wierd problem with my 96 civic ex all of a sudden. It is not the main relay, I know all about those. The other day, I was driving it home from work, and we had a down pour of rain, the streets where almost flooding, and I was driving throught it. My car sputtered and tried to die a couple of times(getting water up in the intake, common, happen's with the cold air intake I have). Any way now when I go to start the car, the starter wont kick on. I have to hold it for awhile (30secs-1min), then all of a sudden the starter will work and the car is good. This happens every single time I try to start the car now.
Anybody have any advice or have heard of this before? Or is the starter going bad?
Old Aug 15, 2005 | 05:28 PM
b20lsvtecCivic's Avatar
Default Re: Car not starting (icer350)
[QUOTE=The other day, I was driving it home from work, and we had a down pour of rain, the streets where almost flooding, and I was driving throught it.?[/QUOTE]
for one u should of never drive in a almost flooding water with a cold air intake..
good chance that u have water in ur engine and will cause major damage in the long run..
if ur car was running fine before u drive it throught a big pudle of water and now its acting up
then you might have to get a new motor cause it will lock up on u...
try not to drive it until u really know y ur car is not staring...
other check for fuel, spark, power,and compression. bc u have to have all 4 working for a car to start
Old Aug 15, 2005 | 05:30 PM
one more thing do u have a cold air bypass for ur intake... ?
Old Aug 15, 2005 | 05:36 PM
icer350's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20lsvtecCivic &raquo;</TD></TR><TR><TD CLASS="quote">
if ur car was running fine before u drive it throught a big pudle of water and now its acting up then you might have to get a new motor cause it will lock up on u...
try not to drive it until u really know y ur car is not staring... </TD></TR></TABLE>
lol... I already told you that the motor is perfectly fine once started.
Alright beyond the point about the cold air intake, the car run's perfectly fine once started. It is not hydro locked, there is no water in the engine.
It is getting it to start is the problem. Anybody ever had this problem or know what it could be?
Old Aug 15, 2005 | 05:42 PM
PXR_2005's Avatar
Banned: Apparently small retailer gone bad.
check your knock sensor or your O2 sensor i have this problem with a customers car doing this but it was a 98 EX same thing though let me know if that helps. or is it throwing a check engine light anywhere?
Old Aug 17, 2005 | 02:26 PM
icer350's Avatar
Default Re: Car not starting (PXR_2005)
no check engine lights anywhere.
I dont understand, how could a knock sensor stop the starter from kicking on?
Old Aug 17, 2005 | 03:11 PM
kkim's Avatar
check for water/moisture in the distributor and the spark plug wells.. you may have spashed some water up high in the engine bay by when you went through the deep water.
honda-spice
Sep 7, 2013 03:31 PM
RickyBizee
19
Jun 18, 2007 11:47 AM
B18 CYA
Feb 29, 2004 01:39 PM
LOWLIFEHATCH
Dec 18, 2003 07:52 AM
