Question about swapping out shift cables in an H22A EG--->HELP!
Old Aug 15, 2005 | 03:05 PM
JDM H23A's Avatar
Default Question about swapping out shift cables in an H22A EG--->HELP!
I'm going to be swapping out my old shift cables for some newer ones. The swap has already been done, so I'll be replacing my 1994 Prelude cables with another set of 1994 Prelude cables that are in better condition. I'd like to do it all in my driveway if possible, so any advice would be helpful. Anybody have a DIY? Thanks!
Old Aug 15, 2005 | 06:43 PM
Six2Six's Avatar
It really shouldn't be that hard. Just unbolt them and remove. Hardest part may be routing them through all that mess of hoses and wires.
Old Aug 15, 2005 | 06:53 PM
95cxh22a's Avatar
Default Re: (Six2Six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Six2Six &raquo;</TD></TR><TR><TD CLASS="quote">It really shouldn't be that hard. Just unbolt them and remove. Hardest part may be routing them through all that mess of hoses and wires.</TD></TR></TABLE>
yea i agree, make sure you do the zip tie mod also, it helped alot back when i had my h22. i would think it would be ok to do it in the driveway.
Old Aug 15, 2005 | 06:59 PM
MrMike's Avatar
Default Re: (95cxh22a)
if its run between the subfram and the fire wall you may need to drop the subfram a little. i like running it between the subfram and firewall cuz it gives it a little more protection from the exhuast heat.
Old Aug 16, 2005 | 09:39 AM
JDM H23A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxh22a &raquo;</TD></TR><TR><TD CLASS="quote">
yea i agree, make sure you do the zip tie mod also, it helped alot back when i had my h22. i would think it would be ok to do it in the driveway.</TD></TR></TABLE>
Thanks everybody! Does anyone have a link to the zip-tie mod?
Old Aug 16, 2005 | 12:25 PM
IHateJDM's Avatar
Default Re: (JDM H23A)
just zip tie the cables together every few inches. It gives you a better 'feel', something cable shift trannies lack. I would also recommend running the cables over the subframe, it'll give more slack in the cables, and make them less prone to wearing out (I've killed 3 sets of shift cables in a year).
korney
Feb 1, 2006 01:57 PM
cpforyou
Jan 13, 2006 05:22 PM
zero2sxity
Dec 11, 2003 12:16 PM
spoonJDMB16acivic
Jun 28, 2003 10:34 AM
F120man
May 13, 2003 06:46 AM
