Integra tranny in a EG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cayman_hatch »</TD></TR><TR><TD CLASS="quote">I know B18 just really is a drop in swop but what about the tranny?
Will an Integra tranny bolt up in a EG6 or does it take modification?</TD></TR></TABLE>
A B-series trans will bolt up to a B-series engine. What car it is really really doesn't matter too much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">Just make sure you have the 94+ integra mounts</TD></TR></TABLE>
It doesn't hurt but I'm pretty sure the tranny mount is the same with B and D series right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">
It doesn't hurt but I'm pretty sure the tranny mount is the same with B and D series right?</TD></TR></TABLE>
From the b18a swap I've done last week, the D-series TOP tranny mount WONT work on a B-series motor
I'm going to say it will NOT WORK since the 3 bolts didn't even line up on the d-series mount to b-series mount(top tranny)
Click the link in my signature and read up on what I posted about the b18 swap into civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ »</TD></TR><TR><TD CLASS="quote">you can use your stock civic mounts...but your going to need the integra rear T bracket for the tranny</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_series_ »</TD></TR><TR><TD CLASS="quote">yep, should bolt right up, and yes you could use stock civic mounts, but you would be better off using the integra mounts.</TD></TR></TABLE>
Have you guys even seen both the mounts and tried to line up the d-series mount on a b-series transmission???? It WONT line up all 3 holes properly. 1 hole will but the other 2 wont
