Need help with wiring for H22 crx
Old Aug 15, 2005 | 01:47 PM
highcomph22's Avatar
Default Need help with wiring for H22 crx
I am in the process of finishing my swap and I need to check my jumper harness wiring. Here is the setup. I have a 90 crx si and I am dropping a 95 H22a. Iam running the p13 ecu and there is a jumper harness ofcourse. I guess I this means I am converting OBD1 ecu to non OBD right? I want to get the pin outs if necessary. TIA
Old Aug 15, 2005 | 09:33 PM
hatch b16a guy's Avatar
Default Re: Need help with wiring for H22 crx (highcomph22)
hey i want to do the h22a swap in a crx but i dont know where to find motor mounts or much on the swap so if u can help me that would be cool i found this website http://www.rywire.com/sitoh22.shtml maybe that will help u
Old Aug 15, 2005 | 11:44 PM
Rywire's Avatar
Default Re: Need help with wiring for H22 crx (hatch b16a guy)
Yes, let us know if you need the wiring job.
Give us a call
Old Aug 15, 2005 | 11:49 PM
sanimalp's Avatar
$cat /dev/urandom
no one makes mounts for the h22 into a crx, atleast not ones that dont require a lot of cutting and welding.hasport has had a version "in production" for atleast a couple years now, and which require welding anyway.. and there have only been a couple people on our forums that have done it at all. look up the user name 2point2 for info. as for wiring, http://www.rywire.com i believe you should be converting from pre-obd to obd1 with vtec atleast, if not obd-2 with vtec.
Old Aug 16, 2005 | 05:59 AM
Default Re: Need help with wiring for H22 crx (sanimalp)
Thanks for the help guys. Iam going to get it off the stands this afternoon. I am not positive what mounts I have I bought the car as an unfinished project.
Reedcrx
Nov 22, 2016 08:25 AM
dadrought6
May 21, 2009 07:37 PM
ransack
30
May 10, 2004 06:39 PM
exploder
Mar 3, 2003 08:41 PM
