K-series in 96-00 civic..need some facts
Old Aug 15, 2005 | 12:24 PM
slvrstns2000's Avatar
Default K-series in 96-00 civic..need some facts
Just trying to find out what needs to be done to get the k20 swap in ek..so far i know
hasport mount kit
custom header
need to know the rest of the wiring and what not..
Thanks
Old Aug 15, 2005 | 06:42 PM
Spoon Si's Avatar
Default Re: K-series in 96-00 civic..need some facts (99crx01)
Wiring Harness..
Axles
Fuel Lines and FPR
K-pro or JDM K20a Ecu
Check out K20a.org for more info on this swap.
Old Aug 16, 2005 | 10:34 AM
BlazedD's Avatar
WestSPEC
custom driveshafts as well..nonoe of the oem ones will fit..
Old Aug 16, 2005 | 11:00 AM
dfoxengr's Avatar
Default Re: (BlazedD)
hybrid-racing mounts,harness, and axles.
hybrid-racing also makes axles for the hasport mount kit
PM me for more ?s
Old Aug 17, 2005 | 08:57 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlazedD &raquo;</TD></TR><TR><TD CLASS="quote">custom driveshafts as well..nonoe of the oem ones will fit..</TD></TR></TABLE>
WRONG INFO!!!!!!!!!!!!!
but you go ahead and do what you want....
http://www.k20a.org &lt;-----go there for k20 questions
Old Aug 17, 2005 | 11:23 AM
Spoon Si's Avatar
it would be custom but it would be a oem custom axle. I believe with the Hasport mounts .
Right Side: K- inners &gt; prelude shaft &gt; B outers "passenger side"
Left Side : K-inners &gt; K shaft &gt; B- outers "tranny side"
This as only been confirmed with Hasport Mounts. I dont know if this will work with any other mounts out there on the market.
Old Aug 17, 2005 | 05:27 PM
B17AGSR's Avatar
I recommend the Karcepts shifter mount kit....you will be able to mount your stock console back in.
Old Aug 21, 2005 | 04:54 PM
rainforest's Avatar
Default Re: K-series in 96-00 civic..need some facts (B17AGSR)
i thought you could do k inners on both and b series outers on both. i have never done the swap before though
Old Aug 21, 2005 | 06:47 PM
chad's Avatar
Moderator
Default Re: K-series in 96-00 civic..need some facts (rainforest)
i have successfully used OEM axels.....
Old Aug 21, 2005 | 10:38 PM
Spoon Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">i thought you could do k inners on both and b series outers on both. i have never done the swap before though
You can use that particular oem combo only on an EG or DC using Hasport mounts.
On the 96-00 models you have to use the prelude shaft on the passenger side.
stuballs12x
Classic Hondas
Apr 16, 2017 04:26 PM
94c1v1cex
May 8, 2007 03:06 PM
JDM_Frijoles
Aug 20, 2006 12:59 PM
ranta18
Jul 28, 2005 12:32 PM
baxter04
Nov 16, 2004 10:02 AM
