NOOB question. I'm gonna get flamed for this, I'm sure...
Old Aug 15, 2005 | 08:59 AM
The_Sober's Avatar
Default NOOB Oil Change Question. I'm gonna get flamed for this, I'm sure...
I have a '93 VTEC. My owner's manual has three different oil amounts listed, but for the VTEC it says I need 4.8L (5.1 US Qts). At the local dealership, they say I only need 4 Qts. Online it says I need 4.8 Qts. The parts dude @ the Autozone where I bought my oil says I need 4 Qts. Jiffy Lube says my car needs 4 Qts.
WTF!!!
I changed my oil, put 4 Qts in and checked the dipstick. It showed at the low end of fine (about 3mm above the lower line). I put another Qt in and it showed 1mm ABOVE the top line. So....how much oil does this goddam H22 need???
Old Aug 15, 2005 | 09:04 AM
The Weather Man's Avatar
I'm pretty sure the dealership and autozone were telling you the minimum - and 4.8 qts must be the maximum.......go for the MIDDLE!....IMO....lol
Old Aug 15, 2005 | 09:09 AM
The_Sober's Avatar
Default Re: (NaptownKing)
lol
Right? I figured "**** it" and I'd put 4qts in and then add until i reached the top of the dipstick line. Turns out that the 5.1qts that the owner's manual says to put in is a little high. That must be the total oil capacity. I probably still had about .25qts in the motor & sump. Ah well, at least I won't have to add any more oil for a while.
Thanks
Old Aug 15, 2005 | 09:10 AM
john d
Guest
Posts: n/a
Default Re: (Sober_John)
i run 5qts
Old Aug 15, 2005 | 09:54 AM
LudemanDan's Avatar
Default Re: (john d)
I don't have my manual handy, but it gives two measurements: one for total (including filter capacity) and one not including the filter. If you changed the filter with the oil - and I hope you did - then you need the larger of the two it gives.
"It" being the owner's manual for your car. Once you have that, you don't need anyone else's opinion!
Dan
Old Aug 15, 2005 | 10:06 AM
bad-monkey's Avatar
5 qts.
Old Aug 15, 2005 | 11:04 AM
flight50's Avatar
Default Re: (bad-monkey)
at my honda shop and everywhere else they put in 5. i had four quarts to put in once because i forgot i did the swap from the f22 which is 4 quarts and they said i needed another quart because I was short.
Old Aug 15, 2005 | 01:33 PM
twistedbydezign's Avatar
Default Re: (flight50)
its at least 5 quarts, when u do the oil change and fill it up with 5 quarts it will be over the line, when u start the car and the oil circulates some of it will stay in places (ie oil filter) and you should be in between the lines after running the engine for a few minutes and letting it drip back down into the pan
vietjdmboi
Apr 18, 2010 07:40 AM
viachicago22
Honda Civic (2006 - 2015)
Jan 31, 2010 01:11 AM
bamboosted
May 10, 2008 01:30 PM
mraza
Aug 8, 2006 06:00 AM
SOHCD16y8
Jun 6, 2005 08:19 PM
