No Spark? Running out of Ideas
Old Aug 15, 2005 | 06:56 AM
RotiEatter's Avatar
Ditto
Default No Spark? Running out of Ideas
Setup is a OBD2 B18C1, MSD SCI, Blaster SS coil, thats the stuff you need to know. I was driving and the car all of a sudden died on me. The check engine light came on but I didnt get a chance to check because I turned the car off when it died and it reset. Well first thing I did was take off my cap and rotor to see if the positive ignitor wire had come off(happened to me before and blew the 15amp ignitor coil fuse).
Nope everything checks out fine. So I try to push start it, it starts but instantly dies. I figure its the MSD Blaster SS coil, buy a new one throw it in and still nothing. I then try my friends distributor off his 99 Si, completly by-passing the MSD, still no spark. We try a stock ecu, bypassing the Hondata, still no spark, new plugs, new wires, still nothing. Tried my conversion harness is my friends car and it cranks right up.
I am getting power to the ignitor, I have confirmed that. I have check every fuse, they are all fine. When i try to crank the car for longer than 7 or so seconds the CEL pops up, code 15=ignition output signal. I am confused and don't know where to go from here, please help guys. TIA
Forgot to mention car is 99 Civic DX
Old Aug 15, 2005 | 09:11 AM
RotiEatter's Avatar
Ditto
Default Re: No Spark? Running out of Ideas (RotiEatter)
I just checked everything behind the dash, turns out it was my tach wire grounding out Everything is good now
Old Aug 15, 2005 | 09:34 AM
blaze the chemi's Avatar
Cool. I was just looking at the Helms for possible senarios. Glad you found it.
mikehawk
14
Jan 10, 2009 01:44 PM
RotiEatter
Aug 23, 2005 09:43 AM
crxzc
Jun 9, 2002 06:50 PM
phildeez
Mar 15, 2002 07:22 PM
