trans problem, It might be jammed
Old Aug 15, 2005 | 04:57 AM
pnltnc's Avatar
Default trans problem, It might be jammed
I've got a gsr hatch, clutch went out yesterday. I pulled everything apart, tried to pull tranny off motor and it wouldn't come off. When I grab the trans I can rotate it right to left but it will not seperate from the motor?? Why is that so? Anybody have the same problem?
Old Aug 15, 2005 | 08:55 AM
doublejz's Avatar
Default Re: trans problem, It might be jammed (pnltnc)
just yank on it, stick a pry/crow bar in there When I pulled mine apart for the first time, after i figured out the starter bolt held it together, it was rough as hell to get apart.....
Old Aug 24, 2005 | 08:08 AM
crx90rcr's Avatar
Default Re: trans problem, It might be jammed (doublejz)
i figured out about that starter bolt also but then i stuck a long iron / steel bar through were the fender is and got it on the lip of the trans and then sludge hammer did the rest
nitewolf
Oct 8, 2014 06:37 PM
pleej
Apr 4, 2011 01:09 PM
_HANS
Oct 3, 2005 08:36 PM
jimmy92civic
Sep 21, 2005 06:51 PM
1DOC422
Oct 6, 2003 03:57 PM
