What are the biggest front brake calipers and brackets that will fit on an EG?
Old Aug 15, 2005 | 01:54 AM
s9civic2i's Avatar
Default What are the biggest front brake calipers and brackets that will fit on an EG?
I have an AEM big brake kit for 92-2000 civic si/ex but the capiler brackets wont take the 12 inch rotors with the kit on my 92 si. The powerslot manual says you have to grind down the oem bracket but that doesnt even come close to helping. What calper/bracket setup can handle 12 inch rotors?? that wil match the caliper bracket holes on my eg?
Old Aug 15, 2005 | 07:22 AM
EG6 SiRII's Avatar
New User
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (s9civic2i)
maybe try contacting AEM...
Old Aug 15, 2005 | 07:31 AM
BauleyCivic's Avatar
Risky Business
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (EG6 SiRII)
Waste of money. Brembo blanks and axxis ultimates own joo.
Old Aug 15, 2005 | 08:20 AM
scott92hatch's Avatar
12.2 but u need 15 at least to fit it
Old Aug 15, 2005 | 08:27 AM
GS-Rcivic's Avatar
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (scott92hatch)
need 16 or bigger for the AEM kit, i have the same one.
Old Aug 15, 2005 | 01:36 PM
s9civic2i's Avatar
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (GS-Rcivic)
welll i already have 16'' slips and they arnt the problem...Powerslot bought this line from aem and all they can tell me is get brake components from an abs car, but my kit is abs and non abs compatible and they really have stopped responding to my emails. THe only reason i got this kit is because i only paid $160 and thats a deal anywhere except i cant put this crap on. I need bigger caliper brackets that will line up with the stock holes on the hub assembly.
Old Aug 15, 2005 | 02:38 PM
eg4matze's Avatar
where can I find a brembo kit for the eg?
Old Aug 15, 2005 | 05:16 PM
4DeepCivic's Avatar
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (eg4matze)
eg4matze: summitracing.com
Old Aug 15, 2005 | 05:18 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (4DeepCivic)
A Brembo kit for an EG will probably cost you about $1300.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Waste of money. Brembo blanks and axxis ultimates own joo.</TD></TR></TABLE>
His idea is better.
Old Aug 16, 2005 | 01:17 AM
eg4matze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DeepCivic &raquo;</TD></TR><TR><TD CLASS="quote">eg4matze: summitracing.com</TD></TR></TABLE>
thx
Old Aug 16, 2005 | 06:03 AM
chad's Avatar
Moderator
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote"> Brembo blanks .</TD></TR></TABLE>
waste of money....
get autozone blanks and a GOOD Pad....
you can fit any sized brake setup on a civic....but YOU DO NOT HAVE THE MONEY to do so!!!
you will have to upgrade your wheels also to get a "BIG BRAKE KIT"
i have itr calipers and rotors under 15 inch brakes....
Old Aug 16, 2005 | 06:05 AM
Risky Business
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
waste of money....
Sorry chad, my bad.
:bowdown:
Old Aug 16, 2005 | 07:01 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Sorry chad, my bad.
:bowdown:
LoL.. wtf?
Anyhow.. You have to be careful with what brakes you use. Like someone else said. You have to have at least 16 inch wheels for the AEM kit, and for ITR calipers as well I believe.
Brembo calipers are pretty big as well..
Normal GSR rotors/calipers bolt right up and, as far as i know, work with anything 14 inch or above. Pretty sure wheels like the 13 inch VX wheels will NOT fit over the calipers.
Old Aug 16, 2005 | 08:05 AM
EGmikeH22's Avatar
* B A N N E D *
13" vx wheels barely fit over VX calipers...
Old Aug 16, 2005 | 09:34 AM
rabius's Avatar
&lt;== rockin the 13" DX wheels!!
woOOoo wooOOoo.
and im not gonna change them either... well, if i can find a tire that doesnt roll so much on them..
gonna do the sleeper thing
Old Aug 16, 2005 | 01:13 PM
chad's Avatar
Moderator
Default Re: What are the biggest front brake calipers and brackets that will fit on an EG? (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">
wrong....15's fit fine...stock and volks and spoon and rega master all fit fine over 15 inch wheels!!!
oh yeah....14 in ce 28n's also fit over ITR calipers.....
Old Aug 16, 2005 | 02:56 PM
s9civic2i's Avatar
haha i dont care about wheel size and all this other stuff you guys are taking about. Is anyone not understanding my question? do i need to make a diagram for someone to get a clue about my issue...i thank all of you for your input and im sure you may have helped someone else but im still stuck.
DarryCar
Suspension & Brakes
Mar 9, 2012 01:29 PM
SiGod
Apr 24, 2011 09:31 PM
Whig-it
May 24, 2005 06:17 PM
EggRolla
10
May 11, 2004 05:07 PM
Blindstuff
14
Jan 22, 2004 06:08 PM
