neuspeed 4 point strut bar!!!!
Old Aug 14, 2005 | 11:12 PM
Greddy Dantegra's Avatar
Default neuspeed 4 point strut bar!!!!
i took out a regular ebay strut bar that was in my integra... than i mount on the neuspeed 4 point strut bar on today.... the steering didnt get stiff it got more loose... i just need help! Is the neuspeed strut bar make the steering more loose?
This is the specs of the suspension i got on my integra
Tokico Illuminas setting is at 4
Ground Control Coilovers with a 1.2 inch drop
Type R sway bars underneath my car
I got a non brand name rear upper strut bar
and this Neuspeed 4 point Strut Bar
I also try stiffing my settings to the max at 5... and its still looose! the Strut bar is mounted so tight to my Upper Control arms... nothing is loose... Imma try lowering my car even more to see if that helps! Or Should i just put back on my old strut bar? Thanx if any of you guys here could help me out!!!!!
Old Aug 15, 2005 | 01:10 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: neuspeed 4 point strut bar!!!! (dvs gsr)
Well, the Neuspeed bar is one of the really good ones out there. Remember, the max setting on the shocks on all 4 corners isn't always the best. Try having the rear tight and the fronts slightly looser.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvs gsr &raquo;</TD></TR><TR><TD CLASS="quote">the Strut bar is mounted so tight to my Upper Control arms... nothing is loose</TD></TR></TABLE>
A bit confused about this. But I think you just worded it wrong.
Old Aug 15, 2005 | 02:17 PM
svtec's Avatar
L D E S
Default Re: neuspeed 4 point strut bar!!!! (shamoo)
that bar owns. i bought one of those for my 4 door civic back in like 1997.
keepin it real.
Old Aug 15, 2005 | 10:33 PM
JDM INSPIRED's Avatar
Default Re: neuspeed 4 point strut bar!!!! (svtec)
i have neuspeed upper tie on my car...nothing wrong with it...this bar have my
shawndb1
Mar 29, 2008 02:43 PM
Rob.
Suspension & Brakes
Feb 22, 2006 08:22 PM
MugenPoweredLude
Dec 2, 2002 08:17 AM
BlueG3Teg
Dec 9, 2001 02:19 PM
