my ls/vtec setup what do you think????
Old Aug 14, 2005 | 10:23 PM
urnotfast's Avatar
Default my ls/vtec setup what do you think????
i am starting on my ls vtec in about a week and im just curious if anybody has a similar setup that can tell me what kind of hp and torque ill be making?
ls block
b16head
b16 piston on ls rods
crower stage2 cams
msd ignition
dc 4-2-1 header
aem cold air
chippped p28
greddy evo exhaust
thats about it if anyone has any suggestions i would like to hear them
peace
eric
Old Aug 15, 2005 | 11:34 AM
New2528's Avatar
What oil pump are u going to use? I would recommend the type r cuz the price isn't that much different than stock b-series.
Old Aug 15, 2005 | 02:18 PM
miller.91.HB's Avatar
Default Re: my ls/vtec setup what do you think???? (urnotfast)
I have an identical setup as you minus the cams. One suggestion would be to ditch the 4-2-1 header. I had the same one and it was the bottle neck in my engine. I would go with a JDM 4-1. Trust me that 4-2-1 is really gonna hold you back from some good numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by New2528 &raquo;</TD></TR><TR><TD CLASS="quote">What oil pump are u going to use? I would recommend the type r cuz the price isn't that much different than stock b-series. </TD></TR></TABLE>
Interesting.... I would really like to know what makes the ITR the best?
Part # 15100-P72-A01
This is the same part number for 1996-2001 Integra RS, LS, GS, GSR, Type R, 1999-2000 Civic SI, and 1997-2001 CRV.
Just make sure you get yourself a vtec oil pump.
Your also gonna want a new water pump (make sure to use the same belt as the water pump). Your going to want new head studs (GSR), new rod bolts (LS) and I would recommend the golden eagle lsvtec kit.
What intake manifold are you using? I had my throttle body bored out by http://www.maxbore.com also.
Modified by miller.91.HB at 5:29 PM 8/15/2005
Old Aug 15, 2005 | 07:10 PM
torqueMONSTER's Avatar
Default Re: my ls/vtec setup what do you think???? (miller.91.HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller.91.HB &raquo;</TD></TR><TR><TD CLASS="quote">I have an identical setup as you minus the cams. One suggestion would be to ditch the 4-2-1 header. I had the same one and it was the bottle neck in my engine. I would go with a JDM 4-1. Trust me that 4-2-1 is really gonna hold you back from some good numbers.[/i]</TD></TR></TABLE>
i have a b20 vtec setup with 4-2-1 greddy headers. how would 4-1 effect my power band? cause i got hella low end torque but mid range is kinda dissipointing
Old Aug 16, 2005 | 08:51 PM
urnotfast's Avatar
ttt
Old Aug 16, 2005 | 09:09 PM
lsvtecracer's Avatar
Just to give you a general idea. my old ls/vtec setup was ls block with b16 pistons and head. I also had skunk 2 im and type r cam. also had a pyr chip with dc 4-1 header. I made 174 to the wheel tune on v-afc. This was about 3 years ago so with a better header like the jdm 4-1 and tune with crome or hondata, etc you should make 190 or so. Of course this is just rough estimate.
Old Aug 16, 2005 | 11:33 PM
urnotfast's Avatar
thanks for the info bro..........thats about what i figured i'd be making
peace
eric
seldon
Sep 28, 2008 02:09 PM
import810
10
Sep 19, 2006 05:44 AM
3a_eg_hatch
Apr 4, 2006 05:11 PM
camera obscura
18
May 26, 2003 03:56 PM
maxxdout
Jan 4, 2002 10:57 AM
