1991 Accord Check engine coming on but not all the time!
Old Aug 14, 2005 | 09:38 PM
chuckmotz's Avatar
Default 1991 Accord Check engine coming on but not all the time!
I replaced the plugs, wires, cap and rotor. And as soon as I started it up it turned over several times before starting and the check engine light came on. It doesn't do it all the time, but if it doesn't come on when I start the car it will run for awhile and then stall. as soon as i start it back up the light comes on????? I checked to make sure all the wires were in the correct place and they are. I was told that it is probably the distributor. Any other suggestions?? How can I get the check engine code?? Please Help!!
1991 Honda accord LX
Old Aug 15, 2005 | 08:32 AM
NAiL05's Avatar
Default Re: 1991 Accord Check engine coming on but not all the time! (chuckmotz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuckmotz &raquo;</TD></TR><TR><TD CLASS="quote">I replaced the plugs, wires, cap and rotor. And as soon as I started it up it turned over several times before starting and the check engine light came on. It doesn't do it all the time, but if it doesn't come on when I start the car it will run for awhile and then stall. as soon as i start it back up the light comes on????? I checked to make sure all the wires were in the correct place and they are. I was told that it is probably the distributor. Any other suggestions?? How can I get the check engine code?? Please Help!!
1991 Honda accord LX</TD></TR></TABLE>
There is a two pin connector under your passenger side dash. Jump it and read the CEL flashes. long flash - 10, short flash - 1.
Old Aug 15, 2005 | 05:52 PM
hondadude's Avatar
This is sort of 'top secret' but since you own a honda.....
http://members.troublecodes.ne...n.jpg
Old Aug 16, 2005 | 02:39 PM
NAiL05's Avatar
Default Re: 1991 Accord Check engine coming on but not all the time! (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">This is sort of 'top secret' but since you own a honda.....
http://members.troublecodes.ne...n.jpg</TD></TR></TABLE>
LOL.
Old Aug 16, 2005 | 07:59 PM
chuckmotz's Avatar
Thanks. I will check it tomorrow.
Cody Anderson
Aug 18, 2014 03:35 PM
91accordflow
Jun 6, 2009 05:12 PM
xkevox
Jul 23, 2008 05:18 PM
slowestcivicever
Jul 20, 2002 03:19 PM
