How to store car for winter?
Old Aug 14, 2005 | 07:03 PM
abmerop18's Avatar
Default How to store car for winter?
I am leaving for college this week and will not be taking my car with me, so I will need to store it in my garage for the time I am there and it will not be driven. Is there anythign special I need to do to make sure it runs good when I bring it back for next summer? I already bought a honda car cover for it, but was wondering if anythign else should be done? I am going to let there be as little gas as possible in it and hopefully my dad will start it and let it run for a bit every month or couple weeks. Am i missing anythign else? Someone said the tires will get bald spots from just sitting there. Is this true?
Old Aug 14, 2005 | 07:12 PM
slowman's Avatar
I took way too long
Default Re: How to store car for winter? (abmerop18)
I dont think the tires would develop bald spots but more like flat spots I think.
Old Aug 14, 2005 | 07:14 PM
The One Upper's Avatar
Put it on jack stands if you dont want to buy new tires
Old Aug 14, 2005 | 07:18 PM
.Beaver's Avatar
Bloody Beaver
Default Re: (The Photographizer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Photographizer &raquo;</TD></TR><TR><TD CLASS="quote">Put it on jack stands if you dont want to buy new tires</TD></TR></TABLE>
abmerop18's Avatar
so the tires will absolutly go bad if i dont put it on stands?
Old Aug 14, 2005 | 07:25 PM
thaiphob's Avatar
Nikon!!!
Default Re: (abmerop18)
youll get a nice flat spot if you dont
Old Aug 14, 2005 | 07:26 PM
.Beaver's Avatar
Bloody Beaver
theres a good chance they will, depends on softness of tire, etc... but it usually is a good idea, I've also heard putting some wood boards under the tires can almost do the same as putting it on jackstands
Old Aug 14, 2005 | 07:29 PM
abmerop18's Avatar
Default Re: (Beaver)
putting it on jackstands doesnt work because my car will need to be moved occassionally to get our lawn mower out of the garage and my dad will be too lazy to put it back on stands. so any other ideas that will work?
Old Aug 14, 2005 | 07:37 PM
.Beaver's Avatar
Bloody Beaver
just put a small piece of plywood under each tire it'll be fine
Old Aug 14, 2005 | 07:38 PM
abmerop18's Avatar
whats the real difference between that and leaving it on the ground then?
abmerop18's Avatar
and should i shoot for more or less gas in the tank?
Old Aug 14, 2005 | 07:47 PM
Ryan.'s Avatar
When having a car sit for long periods of time you should have the car on jackstands or on wood. Also drain all fluids(unless in your case cause car will be started).
So I think for you all you really have to do is keep a decent amount of gas in and park it on some wooden boards.
.Beaver's Avatar
Bloody Beaver
wood is a lil softer than concrete, and I'd say the less gas the better, and I believe you can get gas stabilizer from like autozone, etc... to throw in there, It'll keep the gas from gelling, going bad, etc..
Old Aug 14, 2005 | 07:50 PM
dwnsthGABOY's Avatar
DesioMedia
Jun 1, 2007 04:41 PM
Thirty-Nine
Apr 30, 2007 07:04 PM
Newkdog
Honda S2000
Nov 28, 2005 09:41 AM
Todd Reid
11
Jul 13, 2005 07:51 PM
config
Sep 21, 2003 07:22 AM
