front main seal install (little spring is being a b**ch)
Old Aug 14, 2005 | 06:15 PM
ndogg's Avatar
Default front main seal install (little spring is being a b**ch)
anyone have any advice? the motor is out, i have all the room i need. EVERY time i try and put that thing in, the spring pops out and one part of the seal folds in. i have a socket that fits perfectly on it, i have tried for hours... how the crap do you get this thing in??!?!?!
Old Aug 14, 2005 | 07:09 PM
b18ccivics's Avatar
Default Re: front main seal install (ndogg)
lube it up and slide it home
Old Aug 15, 2005 | 02:15 PM
ndogg's Avatar
bump... anyone else have any tips? i've tried it dry, lubed... whatever... that little bitch will not stay in the rubber.
Old Aug 15, 2005 | 03:32 PM
Crazydave's Avatar
try chilling it in the freezer, maybe it will make it less likely to fold
Old Aug 15, 2005 | 04:12 PM
ndogg's Avatar
Default Re: front main seal install (Crazydave)
thanks for the tip bro... i will try that if i ever need to replace one again. i got it in a few minutes ago. heres what i did:
took off the oil pump and greased the crap out of the inside of the seal as well as the crank. took the new seal and worked it onto the crank without the oil pump there to **** with me... after i could get it on by itself, it seemed to just want to go on correct. so i put it back in the oil pump and slid them on together, and it worked.
that thing was a serious bitch.
88_hatch_ls
Sep 15, 2013 01:25 AM
91(si)hatchey
Nov 6, 2009 12:32 AM
Myztikal
May 2, 2007 10:29 PM
projectTeG
Jul 8, 2006 04:50 PM
warwagon
Sep 25, 2003 09:31 PM
