how do i install this monster tach in my 94 rs??
Old Feb 22, 2002 | 10:43 AM
Acura_I-RS's Avatar
Default how do i install this monster tach in my 94 rs??
i just got it, but there are ni instructions, so i thought id ask, i tried a search, but nothing, so someone please help
Old Feb 22, 2002 | 11:47 AM
drewspeed's Avatar
Default Re: how do i install this monster tach in my 94 rs?? (Acura_I-RS)
The only wire you will need help locating is the tach signal. The black is ground, red is power, green is the tach signal I think and then isn't there a white one as well? Anyways...
Under the dash by the fuse box, there should be a grey connector which is not plugged into the fuse box, it is just clipped to the top of the fuse box. In the middle of this connector runs a blue wire, you can get a tach signal off this one.
I believe the white wire is for illumination.
Hope this helps.
tougetuned_ef
Sep 25, 2010 06:16 AM
pair8hd
Dec 1, 2007 03:44 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
hOndafienD 04
Jun 22, 2004 03:09 PM
yusoslo
Feb 20, 2003 04:40 PM
