Compression test - what fuse to unplug?
Ok, i searched and read a couple articles.
When doing a compression test, i should remove the fuse, right? now, which fuse(s) am I to remove?
I should remove 15A fuse in the fuse box that controls the FI injection. Is there another fuse, such as an ignition fuse, that I should remove?
After that, what exact procedure should i follow to crank the motor over, etc etc
thanks!
thanks!
pull the fuse for the ecu. 15 amp FI / EM.
take out wires and spark plugs, screw in compression tester and then start to crank it a several times until your buddy tells you to stop cranking it.
(have somebody watching the guage, when the compression stops going up, stop cranking it.)
repeat on the other 3 cylinders.
simple
simple
So why not ask this here: https://honda-tech.com/zeroforum?id=44 or : https://honda-tech.com/zeroforum?id=1 ?, Why in the ITR forum?
cuz i like the ITR forum
nah...its just that when i post something in the ITR forum, it gets responded to alot faster imo.
but thanks
but thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">So why not ask this here: https://honda-tech.com/zeroforum?id=44 or : https://honda-tech.com/zeroforum?id=1 ?, Why in the ITR forum?</TD></TR></TABLE>
Cause some of the people here know what they're talking about or they'll make some hilarious smartass rely
memphiss13
Dec 22, 2002 09:51 AM
