Hid retrofit in my jdm teg lights.. how do i do it ??
Old Aug 14, 2005 | 01:38 PM
376R's Avatar
Default Hid retrofit in my jdm teg lights.. how do i do it ??
ok guys when i sold my hatch i kept my hids. they were just plug and play and had to use the housing from the h4 bulb. now, i have a teg with jdm front. non hid lights. id like to know if there is a way to make it work and if so how... the plugs look different. or would it be better to sell the hids and the non hid headlights and get the hid headlights.... i dont know what to do, but i miss my hids. help me out.. thanks
Old Aug 14, 2005 | 09:46 PM
376R's Avatar
Default Re: Hid retrofit in my jdm teg lights.. how do i do it ?? (klubhed1)
Old Aug 14, 2005 | 10:08 PM
rufridn's Avatar
are they bi-xenons, having both low and high beams?
Old Aug 14, 2005 | 10:26 PM
376R's Avatar
Default Re: (rufridn)
no, they came out of 05 maxima... they just plugged right into my eg harness lights and i used the h4 housing, but it looks diffent on jdm teg headlights
Old Aug 14, 2005 | 11:34 PM
Greddy Dantegra's Avatar
plug them in... and adjust it to they way you want them... than silicone it! after that... adjust the height of it by the adjuster on the projectors to make them sit perfectly and even! if it still doesnt work... go pay $100 each bulb and just get the right ones!
Old Aug 15, 2005 | 09:18 AM
376R's Avatar
Default Re: Hid retrofit in my jdm teg lights.. how do i do it ?? (dvs gsr)
confused..... is there another way or is that the only way.... but right bulbs? what kinda bulbs..
Old Aug 15, 2005 | 09:49 AM
Slain's Avatar
i think the jdm non hid is a 9006 .
Old Aug 15, 2005 | 10:16 AM
376R's Avatar
Default Re: (Slain)
i want hid
Old Aug 15, 2005 | 11:13 AM
Slain's Avatar
then get 9006 hid bulbs or some how get the fitting ring from a 9006 over and onto the hid capsule you are using.. will require a bit of dremeling
Old Aug 15, 2005 | 11:23 AM
376R's Avatar
Default Re: (Slain)
the plugs are not the same
Old Aug 17, 2005 | 07:23 AM
376R's Avatar
Default Re: (klubhed1)
Old Aug 17, 2005 | 08:58 AM
hobo_ken's Avatar
buy a new hid kit, 9006. You can't use the H4 bulb kit unless you want to splice into the factory harness, which takes a while.
Old Aug 17, 2005 | 09:03 AM
376R's Avatar
Default Re: (hobo_ken)
that kit will plug right into the headlights too or do i have to make them fit.... where can i find the 9006 kit at and how much is it.. thanks
Old Aug 17, 2005 | 09:30 AM
TunerN00b's Avatar
might want to change the topic title, you aren't doing a retrofit. It sounds like you just want to slap a kit in there, which is really going to blind people, especially with the reversed JDM cutoff.
Old Aug 17, 2005 | 09:45 AM
be.twenty's Avatar
yeah, what you want isn't a retrofit.. but rather a kit.
Old Aug 17, 2005 | 10:59 AM
hobo_ken's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klubhed1 &raquo;</TD></TR><TR><TD CLASS="quote">that kit will plug right into the headlights too or do i have to make them fit.... where can i find the 9006 kit at and how much is it.. thanks </TD></TR></TABLE>
the 9006 kit will plug right into the headlights..you can find it online anywhere, depending on what color/temp you want. The average price is about $250-300.
Old Aug 17, 2005 | 11:00 AM
Naruto's Avatar
Default Re: (da_truf)
it'd be a lot easier to just buy the OEM HID headlight assemblies. You can find cheap deals on good ones on ebay. I bought mine for $750 plus shipping
97 DC2
Jun 9, 2011 12:32 PM
gtrwerks
Jul 1, 2009 05:08 PM
anduhy
11
Jan 25, 2008 05:02 PM
DuNkiN
Aug 27, 2002 07:44 PM
