ZC CRX Swap dilemna
Old Aug 14, 2005 | 11:36 AM
dprestri's Avatar
Default ZC CRX Swap dilemna
I put the dohc zc in my crx yesterday and everything seemed all right when I slowly drove it. The second I give it any gas it bogs down and almost dies. At first I was getting a code 5 for about 1 minute as the car idled roughly. Then it would settle out and throw a code 7. I checked the wiring and thats ok. The timing was fixed and still no progress. The car gets about 35 psi of gas and doesnt lose any pressure when I rev it. I can slowly rev it all the way to redline. IHE and fpr. not too much else except for the integra computer. PLease help. Thank You.
Old Aug 14, 2005 | 03:34 PM
LoneStarCRX's Avatar
Default Re: ZC CRX Swap dilemna (dprestri)
Did you check your MAP sensor and TPS?
Old Aug 14, 2005 | 04:31 PM
JKingCivicSi's Avatar
Did you switch the green/white and yellow/white wires on the TPS harness?
Old Aug 17, 2005 | 05:47 PM
dprestri's Avatar
Wow..that did the trick, Thank you for the info...now i have another problem...my rpms seem to be very high at idle...i checked my vacuum lines and the seem to be alright, but the throttle body seems to be stuck just a little bit open. i cleaned it and it still feels the same. Any ideas? Ill post pics asap. Thnks again.
Old Aug 17, 2005 | 05:49 PM
speedd2286's Avatar
same with me...idles around 1500-2k until warms up then i blip the throttle and goes down to where it should be around 700 rpms
cticknor666
Oct 21, 2010 08:08 PM
crex23
Jan 6, 2008 02:07 PM
drewboy
May 12, 2005 02:58 PM
WhatThaFrig
Apr 4, 2003 09:17 AM
xtremcrx77
Oct 9, 2001 08:08 PM
