Opinions and Estimations on this Build Up
Old Feb 22, 2002 | 09:40 AM
SIINSI's Avatar
Default Opinions and Estimations on this Build Up
Hello,
I have some plans to do my bottom end pretty soon. Can you guys give me some estimates on WHP/TQ and opinions on this setup? Any info is much appreciated.
Stuff I already have....
96-97 JDM ITR Enigne
JUN 3 Cams, Springs, Retainers and Cam Gears
JUN Header
JUN ECU
AEM ITR CAI
Stock bottom end
I dynoed the car with this and got 206 WHP and 134TQ
This is what I am planning on getting. Partially sponsored from my soon to be enginebuilder, Rick Solis from http://www.performanceconcepts-jdm.com/
Golden Eagle Sleeves 85mm
JE 12.3.1 85mm pistons
Eagle Rods
Portflow reworked head
Ferrea .5 oversized valves
All new Bearings, gaskets, seals, balance/blue print
On top of that, I am thinking of switching to ITB's.
I am also planning of chucking the JUN ecu. What do you guys suggest? Hondata?
What kinda power can I lay down if all goes well and I get everything tuned great?
Thanks in advance. I'm open to all suggestions
Miguel
Old Feb 22, 2002 | 09:41 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Opinions and Estimations on this Build Up (SIINSI)
sweet jesus
Might want to do a different header since you`ll be 2.0
Ryan
[Modified by vtecvoodoo, 6:42 PM 2/22/2002]
Old Feb 22, 2002 | 11:32 AM
SIINSI's Avatar
Default Re: Opinions and Estimations on this Build Up (vtecvoodoo)
Man this forum flies!!!
I guess I'll see how the JUN header holds up first It's done me right so far..hehe
Help me out here fellas... I know alot of you guys have my answers
Would it be dangerous to go with oversized valves with the JUN 3's?
Help me out
Miguel
Old Feb 22, 2002 | 11:45 AM
Suprdave's Avatar
Thought about Endyn Pistons? Lip got 242 outta his B18C5 @ 13.5:1 CR.
That was with Toda C's though.
I bet you make 230+WHP with the ITBs and ****.
Are you planning on any tranny work? ATS 4.949? Custom Gearing?
Suprdave
EDIT: I got a new Idea...
Since your using this for N\A...
Why don't you get a stroker crank and a modified piston with raised ring package\pin?
85mm with a 95mm Stroke would get you almost 2.2L
[Modified by Suprdave, 3:10 PM 2/22/2002]
Old Feb 22, 2002 | 11:59 AM
JMendez's Avatar
I was actually thinking of ditching my JUN ecu as well, my set-up is being built right now as well. Very similar to Miguels, just using ITR intake valves instead. 85mm sleeved block with custom JE's. I was leaning towards the 4.7fd because of the power band. ITB's are very enticing, but I just bought a Skunk 2 IM and a 70-68mm Erick's Racing TB. I was looking in a SPEED PRO, I know they have awesome tunability. Maybe we can get a discount if we buy 2? Anymore input is appreciated.
Old Feb 22, 2002 | 12:27 PM
TypeR0149's Avatar
Default Re: Opinions and Estimations on this Build Up (Suprdave)
jeff is 13.5:1 wow
Old Feb 22, 2002 | 12:37 PM
Cheap Bastard's Avatar
New User
I don't think oversized valves are that necessary, because the Jun3's are such long duration cams. Perhaps used should look into Jun's custome intake manifold and t.b. Also perhaps some loud ***, straight through, under the fuel tank N1 exhaust. Preferabley made from Ti.
CB
NirVTEC
Oct 22, 2011 06:52 AM
MaxBoost
13
Jun 6, 2003 07:11 AM
SIINSI
Jun 13, 2002 03:28 PM
AllMotorITR
Feb 12, 2002 06:29 PM
B19CivicHB
Jan 21, 2002 03:39 PM
