Car won't start nor crank
Old Aug 14, 2005 | 08:41 AM
iixerOii's Avatar
Default Car won't start nor crank
I need some possible ideas why my car won't start or crank. I hooked up a booster pack and it won't even crank. I don't hear a clicking noise that is tell tale signs of a bad starter. It's like I just turn my key and nothing happens. I completely disabled my alarm so that can't be it. Any ideas out there guys?
Old Aug 14, 2005 | 08:44 AM
Greddy Dantegra's Avatar
Default Re: Car won't start nor crank (iixerOii)
no cranks? maybe you need a new distrubutor or check your main relay
Old Aug 14, 2005 | 08:57 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Car won't start nor crank (dvs gsr)
Are you getting your interior (dash lights, etc) turning on when you turn the key to ACC? Do you have a multimeter? You can check the starter, etc. Also check your grounds. Have you done any modifications since you noticed your car not being able to start?
Old Aug 14, 2005 | 11:06 AM
iixerOii's Avatar
Default Re: Car won't start nor crank (shamoo)
No mods not even any warning signs of any sorts. I still get radio lights and all that type of stuff.
Old Aug 14, 2005 | 03:34 PM
DJLotus's Avatar
Check the ignition itself. I had the same problems.
Old Aug 14, 2005 | 04:57 PM
Keno20's Avatar
Default Re: (DJLotus)
ive had that problem. My timing belt had snapped!!!! hope its not that!
Old Aug 14, 2005 | 05:02 PM
iixerOii's Avatar
Default Re: (Keno20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keno20 &raquo;</TD></TR><TR><TD CLASS="quote">ive had that problem. My timing belt had snapped!!!! hope its not that! </TD></TR></TABLE>
Dude the very THOUGHT of that scares the **** out of me. If thats the case this only happend after I turned off the car that day and I never drove or was able too so other than the belt it self there shouldn't be too much damage if that happend. Imma have to get this bitch towed tomorrow morning. I have spend my two days off towing and having my car fixed.
Old Aug 14, 2005 | 05:22 PM
iixerOii's Avatar
Default Re: (iixerOii)
Any possibility it could be my main fuel relay?
Old Aug 14, 2005 | 06:11 PM
Keno20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iixerOii &raquo;</TD></TR><TR><TD CLASS="quote">Any possibility it could be my main fuel relay?</TD></TR></TABLE>
When the main fuel relay is at fault, it usually causes the car to not start or even crank, when the car is warm. The car will usually start up all good when cold. Having said that I would'nt rule the idea out.
Old Aug 14, 2005 | 08:01 PM
iixerOii's Avatar
I just swaped out a good relay and it still didn't work
JorgeR559
Jun 10, 2014 10:50 AM
PhantomX
Apr 6, 2008 09:15 AM
sabot808
Apr 21, 2007 09:37 PM
RockLee`
Sep 18, 2005 06:30 PM
Bklyn TSi
Sep 24, 2001 11:39 PM
