Eagle crankshaft vs Crower crankshaft.....which is beta??
Old Aug 14, 2005 | 07:41 AM
cyrix12's Avatar
Default Eagle crankshaft vs Crower crankshaft.....which is beta??
anyone care to enlighten??
Old Aug 14, 2005 | 04:24 PM
NJIN BUILDR's Avatar
Default Re: Eagle crankshaft vs Crower crankshaft.....which is beta?? (cyrix12)
The price is "better" on the Eagle.The quality is "better" on the Crower.The quality is more than acceptable for most applications with the Eagle.
Glenn
Old Aug 14, 2005 | 06:25 PM
cyrix12's Avatar
Default Re: Eagle crankshaft vs Crower crankshaft.....which is beta?? (NJIN BUILDR)
Hi....thks a lot...has made decision making so much easier....
Old Aug 14, 2005 | 06:41 PM
PURPLETERROR aka BIGMATT's Avatar
do you plan on building a stroker motor?
Old Aug 14, 2005 | 06:43 PM
cyrix12's Avatar
Default Re: Eagle crankshaft vs Crower crankshaft.....which is beta?? (PURPLETERROR)
me??..me planning to build a 85mm 2L motor....but wat u mean by stroker motor??...sori..not so much a tech person....could you elaborate a bit??
Old Aug 14, 2005 | 06:56 PM
What is your reasoning for wanting to use a crower or eagle crank? Your oem honda crank is steel and balanced from the factory. The only reason I would upgrade to an aftermarket crank is if i wanted a longer stroke than an ls crank.
Old Aug 14, 2005 | 07:02 PM
pomansouth01's Avatar
Ginger Kid
yea, the stock crank is more then sufficient for as much horsepower as you can make, the only reason for going with a billet crank would be to get a longer stroke.
VTC#2
May 23, 2013 02:28 PM
logg_frogg
Dec 19, 2007 04:37 PM
sour97
Sep 30, 2007 05:05 PM
rudebwoy
Jul 22, 2007 03:03 PM
mec. pedri
Feb 25, 2006 05:26 PM
