GT40R vs PT71 GTQ........
Old Aug 14, 2005 | 07:05 AM
b00stedbyFastrax's Avatar
Default GT40R vs PT71 GTQ........
how does the gt40r compare to the PT71 GTQ in terms of POWER and spool up.
Old Aug 14, 2005 | 11:07 AM
TheShodan's Avatar
Moderator
Default Re: GT40R vs PT71 GTQ........ (b00stedbyFastrax)
At those power levels that those turbos were designed for, honestly, spool up should not be a concern. Only power output. Those are NOT street/dragstrip type designs. Those are the serious almost track only condition turbos.
Old Aug 14, 2005 | 05:39 PM
Default Re: GT40R vs PT71 GTQ........ (TheShodan)
TTT
Old Aug 14, 2005 | 05:57 PM
SFWD 1934's Avatar
http://www.turbobygarrett.com/...2.htm
http://precisionturbo.net/turb...=3027
Check with a couple of the racers that have used the PT71-GTQ. I know Cort used it, but he is doing something different now from what I uderstand. The PT71 will allow you to get about 80 hp more in the bigger trim.
http://www.atpturbo.com/Mercha...e=GRT
Good luck,
Jason
Old Aug 14, 2005 | 06:33 PM
Axel Foley's Avatar
also curious about spool and which one flows more
Old Aug 14, 2005 | 07:09 PM
Boostfed's Avatar
New User
Funny you posted this. I had a Pt71GTQ on order THEN the GT40R became available. I asked a couple of good tuners and engine builders, top turbo guys which one I should do. This is what i was told "Do you want to get down the track faster? Then GT40R! If you want to be a dyno queen then PT71GTQ!" I chose the GT40R but I dunno if the above statements are necessarily true BUT we shall find out REAL SOON!
Old Aug 14, 2005 | 07:54 PM
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Funny you posted this. I had a Pt71GTQ on order THEN the GT40R became available. I asked a couple of good tuners and engine builders, top turbo guys which one I should do. This is what i was told "Do you want to get down the track faster? Then GT40R! If you want to be a dyno queen then PT71GTQ!" I chose the GT40R but I dunno if the above statements are necessarily true BUT we shall find out REAL SOON! </TD></TR></TABLE>
sooooo, the gt40r will produce a more useable powerband and make about the same power at per say 30psi @ 8500, whereas, the PT71 GTQ will produce more power when revving the **** out of the engine.
Old Aug 14, 2005 | 09:16 PM
uglyasscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Funny you posted this. I had a Pt71GTQ on order THEN the GT40R became available. I asked a couple of good tuners and engine builders, top turbo guys which one I should do. This is what i was told "Do you want to get down the track faster? Then GT40R! If you want to be a dyno queen then PT71GTQ!" I chose the GT40R but I dunno if the above statements are necessarily true BUT we shall find out REAL SOON! </TD></TR></TABLE>DYNO QUEEN?! bitch you almost made me laugh. I put the GT40R on and I could only run a 12 second pass. I put the PT71 back on and ran five 10.00s in a row and turned into Joe Simpson. J/K
No really....I think the GT40R will destroy the PT71 in spool time and reliability. But my presonal PT71 will destroy any GT40 out there. My 71 is a little different then the current PT71's.
There will be some new 71mm turbo's floating around soon from a couple different companies that will be tested soon. You guys will be the first to here about the test results.
Old Aug 14, 2005 | 09:40 PM
Boostfed's Avatar
New User
Default Re: (uglyasscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic &raquo;</TD></TR><TR><TD CLASS="quote">DYNO QUEEN?! bitch you almost made me laugh. I put the GT40R on and I could only run a 12 second pass. I put the PT71 back on and ran five 10.00s in a row and turned into Joe Simpson. J/K
There will be some new 71mm turbo's floating around soon from a couple different companies that will be tested soon. You guys will be the first to here about the test results. </TD></TR></TABLE>
Doh should've got the PT71 for Dyno Queen status!!! I think the new bandwagon is the Gt42R
Old Aug 14, 2005 | 10:02 PM
G
sh!t happens.
I hate turbos.... so many to choose from.. DAMNIT
Old Aug 14, 2005 | 10:17 PM
liam821's Avatar
25 Year Member
Default Re: (G"UNIT)
Cortney gave me a ride around the block when i was up in Utah in his hatch with a PT71gtq. Honestly that thing isnt laggy at all. Shes starts to spool mid 4000rpm and by a split second later its on the rev limiter with the front tires on fire. 480whp on pump gas (or something like that). It was super gnarly. I believe cort dynoed 803whp with that thing (search in the archives he posted it). Ran a 9.9 @ low ~150mph.
The same day we went out in another car with a gt40r, and i thought that was much lagger IMO. Still fast mind you...haha
liam
Old Aug 14, 2005 | 10:27 PM
Boostfed's Avatar
New User
Default Re: (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">Cortney gave me a ride around the block when i was up in Utah in his hatch with a PT71gtq. Honestly that thing isnt laggy at all. Shes starts to spool mid 4000rpm and by a split second later its on the rev limiter with the front tires on fire. 480whp on pump gas (or something like that). It was super gnarly. I believe cort dynoed 803whp with that thing (search in the archives he posted it). Ran a 9.9 @ low ~150mph.
liam</TD></TR></TABLE>
Weird well one thing is the PT71GTQ that Cort has is only a .68 A/R turbine with housing with of course a GTQ turbine wheel then teh GT40R I have has a .95 A/R turbine housing and of course the GT40R turbine wheel which is bigger than a GTQ. I dunno we shall see if the GT40R is a good match on my motor, we should be dropping it in tomorrow or Tuesday!
Old Aug 14, 2005 | 10:39 PM
M.A.R.C.'s Avatar
SC61 &gt; PT71 and GT40R... or was that 2004??? damnit am i late again?
Old Aug 14, 2005 | 10:45 PM
liam821's Avatar
25 Year Member
Weird well one thing is the PT71GTQ that Cort has is only a .68 A/R turbine with housing with of course a GTQ turbine wheel then teh GT40R I have has a .95 A/R turbine housing and of course the GT40R turbine wheel which is bigger than a GTQ. I dunno we shall see if the GT40R is a good match on my motor, we should be dropping it in tomorrow or Tuesday! </TD></TR></TABLE>
Correct cort had the .68ar exhaust. It really did spool quick!!! You gotta report back and let us all know how the gt40r with the .95ar spools - thats a big turbo!!!
liam
Old Aug 15, 2005 | 07:13 PM
what is the availability of the Gt40R?
Old Aug 16, 2005 | 05:18 PM
TheShodan's Avatar
Moderator
Default Re: (b00stedbyFastrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedbyFastrax &raquo;</TD></TR><TR><TD CLASS="quote">what is the availability of the Gt40R?</TD></TR></TABLE>
Usually I can get those in about a week or so, usually special order. Most people don't keep it in stock.
Old Aug 16, 2005 | 05:22 PM
b16sedan's Avatar
What are we talking about, a 71mm comp wheel on a GT42R turbine?
Old Aug 16, 2005 | 05:25 PM
Boostfed's Avatar
New User
I PM'ed you, I can get ahold of 3 right now
Old Aug 16, 2005 | 06:27 PM
BOOSTEDS2K's Avatar
I have a PT72.. the spool time is kinda not cool ful boost @7000 rpm but with NOS it spools faster!! I would do a lot of research!
Old Aug 20, 2005 | 11:29 AM
99_GS-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Weird well one thing is the PT71GTQ that Cort has is only a .68 A/R turbine with housing with of course a GTQ turbine wheel then teh GT40R I have has a .95 A/R turbine housing and of course the GT40R turbine wheel which is bigger than a GTQ. I dunno we shall see if the GT40R is a good match on my motor, we should be dropping it in tomorrow or Tuesday! </TD></TR></TABLE>
The GTQ turbine is a 79mm inducer/68mm exducer.
On the GT40R, I have found various specifications on the trim. The 73 trim GT40R is a 77mm inducer/65.8mm exducer. The 78 trim GT40 turbine is 77mm inducer/68mm exducer. There might also be an 84-trim GT40R, which would be 77 inducer/70.6 exducer.
The GTQ is larger then all but the 84-trim, which I'm not 100% sure is even avaliable.
Cort, I'm interested in hearing about these 71mm turbochargers coming out. I've been talking with a company about a turbo that meets exactly SFWD rule limits and it is targeted for high pressure ratios with reasonable spool.
ashoka
Oct 27, 2005 07:52 AM
Ex-ITR5874
Mar 2, 2003 02:00 AM
