FS: Type R rear sway bar with bsq mounting kit
SOLD!!!!!!!!!!For DC chassis. New in box never used or opened. Just never got around to installing and wont have car much longer. $125 plus shipping for the bar and kit. One of the best suspension mods available!
Modified by tygsr at 10:47 AM 9/21/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose »</TD></TR><TR><TD CLASS="quote">I'm local, explain bsq mounting kit? </TD></TR></TABLE>
Basically two mounting plates, two washers, and two spacers. It basically allows you to mount the ITR sway bracket.
Check this link out...
http://geocities.com/bretq/swaybar_install.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose »</TD></TR><TR><TD CLASS="quote">thanks veggie. I'm gonna need another thing such as beaks mounting kit if I wanna save my subframe correct? </TD></TR></TABLE>
Nope BSQ kit will do the job. That is what it is for is subframe reinforcement. Let me know if your interested.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose »</TD></TR><TR><TD CLASS="quote">do you have any pics of the bsq kit? I'm still interested</TD></TR></TABLE>
I do, on my car. Ill snap some pics later on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose »</TD></TR><TR><TD CLASS="quote">yea I'm just worried about it. I heard of a couple incidents of the beaks tearing subframes</TD></TR></TABLE>
well, if you rally the **** out of it, yeah, you have that potential. But there are ways to alleviate that stress. Anyway, heres a shot of it on my car. Also, to do it the right way, its best to take off the abs bracket, but i was lazy and didnt.
on me.
on me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster »</TD></TR><TR><TD CLASS="quote">
well, if you rally the **** out of it, yeah, you have that potential. But there are ways to alleviate that stress. Anyway, heres a shot of it on my car. Also, to do it the right way, its best to take off the abs bracket, but i was lazy and didnt. on me.
I've tracked the HELL out of my car with a 23mm bar and the BSQ kit has held up fine. I plan on moving upto a 26mm bar, and will still use the BSQ kit. You will not have any worries as long as you install it correctly.
GOOD deal also
GOOD deal also
on me.
There is no reason to remove the ABS sensor wire brackets. They don't interfer with the installation of the swaybar.
on me.
</TD></TR></TABLE>There is no reason to remove the ABS sensor wire brackets. They don't interfer with the installation of the swaybar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tygsr »</TD></TR><TR><TD CLASS="quote">up!</TD></TR></TABLE>
Someone buy this ish...good deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSQ »</TD></TR><TR><TD CLASS="quote">There is no reason to remove the ABS sensor wire brackets. They don't interfer with the installation of the swaybar.</TD></TR></TABLE>
Really, when i installed it, it was a tight fit so i figured removing the bracket would open it up a bit. Anyway, good to know.
