NGK Sparks and wires; Iridiums or regular?
Old Aug 13, 2005 | 06:15 PM
97LXAcc0rd's Avatar
Default NGK Sparks and wires; Iridiums or regular?
Topic says it all. Iridiums or regular ones, by NGK? I have a 97 accord.
Old Aug 13, 2005 | 06:18 PM
Diego Dangers.'s Avatar
regular NGKs are fine, iridiums just basically last longer, but its so easy to change that they are kinda pointless, atleast to me.
Old Aug 14, 2005 | 12:55 AM
The_Todd's Avatar
Farts in the shower
Default Re: NGK Sparks and wires; Iridiums or regular? (97LXAcc0rd)
Iridiums if you have a v6 because they are a PITA to change, regulars if you have a 4 cylinder.
ngk = oem honda
Old Aug 14, 2005 | 06:56 AM
97LXAcc0rd's Avatar
thanks for the replies. anyone know if there's a tutorial or if someone can guide me step-by-step on how to change the spark plugs? i have an f22b2. thanks.
Old Aug 14, 2005 | 07:31 AM
deserthonda's Avatar
yo 97......... go to SEARS... get a racket. an extension and a spark plug socket........to avoid mis-repositioning plug wires. remove wires 1 at a time and replace plug then reconnect plug wire or get a piece of tape and mark each plug wire before u take it out then u can remove them all at once ,,it is a very easy job . put a little bit of anti-seize on spark plug threads ......if u need further assistance holler
Old Aug 14, 2005 | 01:34 PM
NAiL05's Avatar
Default Re: NGK Sparks and wires; Iridiums or regular? (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">yo 97......... go to SEARS... get a racket. an extension and a spark plug socket........to avoid mis-repositioning plug wires. remove wires 1 at a time and replace plug then reconnect plug wire or get a piece of tape and mark each plug wire before u take it out then u can remove them all at once ,,it is a very easy job . put a little bit of anti-seize on spark plug threads ......if u need further assistance holler </TD></TR></TABLE>
Make sure your spark plug socket is 5/8. When you put in the spark plug DO NOT drop it in the hole. Put it in with the socket.
prolifik22
Feb 22, 2008 11:30 PM
JDM_SOHC
Apr 30, 2007 02:24 PM
chinolal
Sep 30, 2006 08:59 PM
slickrc
Aug 3, 2005 06:39 AM
wannakno
Nov 26, 2002 08:32 PM
