vibration in front end
I HAVE A 94 ACCORD EX AND THE FRONT END SHAKES AT HIGHWAY SPEEDS. I HAD THE WHEELS CHECKED AND REBALANCED AND IT STILL DOES THE SAME THING. CAN ANYBODY OUT THERE TELL ME WHAT WOULD CAUSE THIS?
hmm...maybe check cv boots/axles. try turning your steering wheel all the way to one side and check the black, plastic looking thing. if it's busted open and leaking grease, then there's your problem. hope that helped!
Without applying the brakes:
Out of balance tires (you said you had those checked)
Bent wheel/rim
Broken belt in tire
Worn Tie Rods (either inner or outer)
With brakes applied:
Brake Rotors
If you feel it more in the steering wheel, It's the front(s)
If you feel it more in the seat, It's in the rear
If you feel the car weebling from side to side while rolling slowly, it's tires
P
Bent wheel/rim
Broken belt in tire
Brake Rotors
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97LXAcc0rd »</TD></TR><TR><TD CLASS="quote">hmm...maybe check cv boots/axles. try turning your steering wheel all the way to one side and check the black, plastic looking thing. if it's busted open and leaking grease, then there's your problem. hope that helped!</TD></TR></TABLE>
yo 97 ripped cv boots will not make a car shake as a matter of facts just a ripped cv boot will not do anything unusual except ruin the joint if u dont replace it so it is not cv boots ...like other suggested i would recheck balance, bent rims ?? loose frt suspension components ??.. try rotating frt wheels to rear and test drive ..
yes it does it only between 65-70. i have allready switched the tires front to back and got the same shake it feels like the tires are out of balance but there not
raise car , hold oj frt wheels and chk for play side to side and up/ dpwn if u feel any play u got worn suspension parts.. ball joints, tie rods / ends , ........if all is ok i would have another shop balance my wheels
I'd check the ball joints first as they take a beating of you constantly rub the curb. If your lower joint is going out, it will cause the car to shake at hwy speeds
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda »</TD></TR><TR><TD CLASS="quote">raise car , hold oj frt wheels and chk for play side to side and up/ dpwn if u feel any play u got worn suspension parts.. ball joints, tie rods / ends , ........if all is ok i would have another shop balance my wheels </TD></TR></TABLE>
to add to this, I believe side to side is usually tie rod and up and down movement is balljoint, no?
im pretty shure that eaither your engine mounts are old and worn or you have too much power for your stock mounts my best guess from experience
whiteformula98
11
Nov 9, 2015 06:58 AM
cdmef
Dec 20, 2008 07:17 AM
