b16a1 swapped in ctr cams with gears...no a problem
Old Aug 13, 2005 | 04:14 PM
MessGSR's Avatar
Default b16a1 swapped in ctr cams with gears...now a problem!!!
just put in ctr cams and skunk 2 cam gears....drove around the block now, i have a 23 code(knock sensor) i dnt know why...could it be the timing of the cam gears. i have the intake +2 and exhaust -2 plz help...thanks
Old Aug 13, 2005 | 04:27 PM
daidilus's Avatar
well first i would check the corresponding sensor
Old Aug 13, 2005 | 04:32 PM
MessGSR's Avatar
Default Re: (daidilus)
i just checked it with my multi meter...ran contanuity test...i tink i have to lash valves
Old Aug 13, 2005 | 05:28 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: b16a1 swapped in ctr cams with gears...now a problem!!! (MessGSR)
Set the cams to stock, 0 0.
Set the distributor to stock. I can't remember if it is 16 BTDC, but you should have mark on the top distributor with the correct setting.
I would not mess with the timing unless you have AF meter and a dyno. The knock sensor is on because it can't retard the ignition timing enough.
Old Aug 13, 2005 | 10:00 PM
CaliforniaHighwayPatrol's Avatar
How does the car feel with the CTR cams in, thinking about doing it myself also
moddedmuskegon
May 2, 2008 09:41 AM
G2Fanatic
Feb 23, 2008 04:35 PM
HybridIntegra
Jan 16, 2004 12:06 AM
