DOHC VTEC oil pressure at head problem
Old Aug 13, 2005 | 02:52 PM
bigmacks's Avatar
Default DOHC VTEC oil pressure at head problem
i have an ls/vtec in my del sol. my vtec is not working i have 2 oil pressure gauges in my car one at the back of the block and one at the vtec test port at the front of the head. block oil pressure is normal at 10-15psi at idle to 80 at high revs, i do have the full psi at the end of the ls/vtec line but not at the other side of the head only getting less then 15. solenoid is clean and clicks and activates at 5000rpm like my computer is chipped to do. it turns my engine light on if i drive in vtec for a short period of time throws a code 22 but i have tried 3 different vtec pressure sensors and that is not it, it is definetly oil pressure problem. i even switched where the line taps into the head to the 1/8 hole . any advice would be helpful.........
Old Aug 14, 2005 | 01:57 PM
bigmacks's Avatar
bump
Old Aug 15, 2005 | 11:40 AM
New2528's Avatar
what do u mean by getting full presure at the lsvtec line? It coming out of the block or going into the head? Normally oil pressure should read about 50-60psi in the front port of the head when the VTEC is engaged.
Old Aug 16, 2005 | 09:26 PM
lsvtecracer's Avatar
Default Re: (New2528)
You usually won't see oil pressure on the front of the head until vtec kick in. check your wiring to see if there is a loose connection.
Old Aug 18, 2005 | 05:01 PM
bigmacks's Avatar
the line i ran from the block to the head for oil definelty has full oil pressure and i have tested the solenoid for vtec and it works i can jump it too. the pressure at the head is only 15 at most
Old Aug 18, 2005 | 05:02 PM
bigmacks's Avatar
and lsvtecracer can you fell th vtec in your ls/vtec and you had no problems with oil presuure i guess
Old Aug 18, 2005 | 05:16 PM
rainforest's Avatar
Default Re: (bigmacks)
was this motor just built. here are a few things to check
the vtec selonoid screen could be clogged
check for continuity/resistance at teh oil pressure switch
check d6 to the pressure switch for continuity
also check that all of the cam caps are tight i just had a friend that had a missing bolt on the cam cap that lost oil pressure at the pressure switch.
Old Aug 18, 2005 | 05:24 PM
bigmacks's Avatar
i know the ecu is switching the solenoid and have checked and cleaned it a few times. the motor is fresh. and all cam bolts ar tight the only thing that has me thinking is the 2 very last bolts in th head on the far right (bside the cam gears) i had to replace does anyone know the exact length of them.
Old Aug 18, 2005 | 08:06 PM
I can feel vtec kick in with no problem. My oil pressure gauge read about 65 to 70 psi of oil when vtec kick in. the guage sending unit is on the back of the block.
Old Aug 19, 2005 | 03:40 PM
sycamore
Guest
Posts: n/a
did you use a 4 an line (for oil feed) and what about your oil pump did your use the vtec one if now try that the dif if 30 psi. and the code 22 is vtec my friends car did that we dont know you but it was cool it hit vtec on a ls ecu. dont know what to tell you just turn your car off and then back on real quick when you are driveing then it will quit throughing check engine and one a day reset your ecu.
Old Aug 22, 2005 | 10:57 AM
Targa4Life's Avatar
Default Re: (sycamore)
I have the same oil prolem in my ls/vtec and so does my freind in his b20/vtec. I do not agree with putting in a vtec oil pump because the b20 oil pump has the same part number and the vtec one from honda and my freind still has the problem so what gives???? Anyway I have treid going to the -4an feed line to the head and it still makes no difference. If anything, the bigger feed line just takes longer to fill up and begin lubricating the cams upon start up. IMO I will never build another Ls/Vtec. Next one going to have b18C1 or c5 inscribed......
Old Aug 24, 2005 | 12:17 PM
sycamore
Guest
Posts: n/a
the in side of the 4an feed is the same size as the fitting and you dont have to use a vtec oil pump on a b20 but you shoud use it on ls vtec also a vtec watter pump. but every one has there own opinion.
Old Aug 24, 2005 | 07:50 PM
DOHCtorTHRUST's Avatar
this may be a long shot but, did you put the dowel pin on the cam caps? its something that commonly happens.
Old Aug 24, 2005 | 08:41 PM
Default Re: (DOHCtorTHRUST)
My oil feed line for my ls/vtec is actually 6an line. I did have a problem with my b20vtec with vtec not kicking in. It turn out I had air in the line and after a couple of day of driving it solve itself. It is correct that the b20 oil pump is the same as the vtec one. I had used an 8an line before and it still work out fine. I believe that you might have air in your oil feed line.
Old Aug 25, 2005 | 02:08 PM
bigmacks's Avatar
DOHCtorTHRUST they are pressed into the caps right? and i dont think there is air in my line cuz the oil comes out the front of the head
BCSi00
Sep 24, 2020 12:09 AM
queez
Jan 3, 2005 06:12 PM
lemongreenhatch
Jun 26, 2004 07:24 AM
lemongreenhatch
Jun 23, 2004 07:02 PM
zdr262
Oct 23, 2001 09:29 PM
