VTEC kick in at 6200rpm?
Old Aug 13, 2005 | 01:56 PM
Honda Sport's Avatar
Default VTEC kick in at 6200rpm?
just finished up my lil bro's EG gsr swap. no CELs. everything is hooked up correctly ie. VTEC selenoid, VTEC oil pressure, IAB, knock sensor, etc. anyways, I thought that the dual butteryfly intake manifold opens around 4400rpm and VTEC at 5500 rpm? the only time I feel a pull is at 6200 rpm. can the stock rpm gauge cluster be off? I'm using an EX/SI stock cluster. I can rev it to 8k no problems. I'm pretty sure the p72 that we're using is stock. any thoughts?
Old Aug 13, 2005 | 08:34 PM
RynoDyno312's Avatar
Default Re: VTEC kick in at 6200rpm? (Honda Sport)
If it's a stock GSR engine than the VTEC is at 4400 and the secondaries open at 5800.
Old Aug 14, 2005 | 03:29 AM
DohcVtecCrx's Avatar
Default Re: VTEC kick in at 6200rpm? (RynoDyno312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RynoDyno312 &raquo;</TD></TR><TR><TD CLASS="quote">If it's a stock GSR engine than the VTEC is at 4400 and the secondaries open at 5800.</TD></TR></TABLE>
exactly what I was going to say, I thought the iab's were a hair lower but sounds close enough for me!
Old Aug 14, 2005 | 08:50 PM
yup, stock motor, stock p72 ecu. the only mod is a short ram intake. so anybody know why it's kickin in at 6200rpm?
Old Aug 15, 2005 | 08:10 AM
99exd16y8's Avatar
Default Re: (Honda Sport)
It isnt, what you are hearing are the secondaries opening up, they open @ 5750. Your stock tack is off a little from the factory about 500 pms. Vtec on a stock gsr is not very noticeable. But if you were to get a a chipped ecu with a different vtec crossover point the difference would be night and day.
Old Aug 15, 2005 | 11:28 AM
cool. thanks. just weird that the secondaries sounded like they would open up so late.
EFboosted
Oct 14, 2008 01:18 PM
polishedturd
Dec 6, 2007 10:24 AM
jedsus
Jul 1, 2006 09:47 AM
Bonzai1994
Aug 16, 2005 03:32 PM
