tech question...need advice/shortcut...
Old Aug 13, 2005 | 01:03 PM
NA2000's Avatar
Default tech question...need advice/shortcut...
Ok, well my crankshaft pulley key sheared the other day...Any clever ideas on how to remove the pulley??
Modified by blueg9 at 4:04 PM 8/13/2005
Modified by blueg9 at 4:07 PM 8/13/2005
Old Aug 13, 2005 | 03:09 PM
NA2000's Avatar
Default Re: tech question...need advice/shortcut... (blueg9)
bump, need some help
Old Aug 13, 2005 | 03:53 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
wedge something in the flywheel teeth??? i dunno just guessin
free bump
Old Aug 13, 2005 | 05:12 PM
NA2000's Avatar
Default Re: tech question...need advice/shortcut... (2000psi)
yeah I tried that but it's hard to find something small enough to fit in the small teeth clearance that is actually strong enough to hold the torque necessary to loosen it...thanks for the suggestion...
Old Aug 13, 2005 | 06:12 PM
hAILO's Avatar
have u tried something called a prying screwdriver?
Old Aug 13, 2005 | 06:30 PM
NA2000's Avatar
Default Re: tech question...need advice/shortcut... (hAILO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAILO &raquo;</TD></TR><TR><TD CLASS="quote">have u tried something called a prying screwdriver? </TD></TR></TABLE>
WTF?? No..
Old Aug 13, 2005 | 10:01 PM
eg6T's Avatar
ummm i think i used a ball joint remover or something like that it has 3 little legs and a screw..here is a pic.works wonders
the last one onthe page is what i have
http://www.matcotools.com/Cata...elect
Old Aug 13, 2005 | 10:02 PM
eg6T's Avatar
Default Re: tech question...need advice/shortcut... (eg6T)
no wait i think i have the 2 ton...def. didnt spend $121 on the 7 ton
Old Aug 13, 2005 | 10:23 PM
NA2000's Avatar
alright, I have one of those but I should've explained a little better what's going on...The pulley is loose, probably like an inch of play either was so it's loose and I think that the screw is like a thread or two out already...But it still doesn't move ...Could it be seized into the crank? How could I find out?
Old Aug 20, 2005 | 03:45 AM
i_kick_turtles's Avatar
wait, so you think the bolt going into the crank is seized? is that whats going on?
Old Aug 20, 2005 | 06:28 AM
NA2000's Avatar
Default Re: tech question...need advice/shortcut... (I R Tylor)
it's chill, i got it...just haven't been on to lately...Nothing the impact wrench couldn't fix, just had to find one..Thanks for the help everyone
Turbo O
Nov 8, 2007 12:22 PM
porter
Feb 4, 2007 11:11 AM
dc28012
Sep 21, 2006 01:31 AM
scarface50370
Dec 3, 2005 06:45 PM
SLOAZZ95
Aug 2, 2004 08:05 AM
