uneven pad wear
My driver side front pads just wore out to the point where it started to eat up my rotors. I changed my front pads and I notice the the pads on the pass. side still looked new, while my driver's side are all the way worn. What causes this uneven wear? I replaced it with hawk pads, and I notice that I get a lot more brake dust on the driver side, which means that it's wearing out much faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tranceologist »</TD></TR><TR><TD CLASS="quote">you might have a locked caliper</TD></TR></TABLE>
if he did, then it would smell like burning brakes all day long..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">bleed your brakes and make sure that fluid is flowing through the passenger side like it should.</TD></TR></TABLE>
What? That makes no sense.
I have a bad caliper on back that doesn't work very well. I dont smell burning all day but it is locking up. the seal is bad around the piston and hard to move. so it could be a bad caliper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">What? That makes no sense.</TD></TR></TABLE>
It makes perfect sense if you possibly have a clogged line... I had a bad line in the rear... After several months pads and rotors looked like new. When I tried to bleed the brakes hardly any fluid came out of the line. I replaced the line and everything was fine after that...
Mikes2000civicsi
10
Jan 14, 2007 04:35 AM
